Fiesta rs turbo fuel pump
Old Jul 27, 2015 | 12:56 PM
Gem frst's Avatar
Gem frst
Default Fiesta rs turbo fuel pump
Need a little help my fuel pump it's not priming checked with new relay and no better when I connect straight to a battery fuel pump works so what do I check next how can I get over this
Old Jul 27, 2015 | 03:49 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
There's a second relay for the injection system, if that doesn't work then the fuel pump relay doesn't either, if not then could be a wiring problem.
Old Jul 27, 2015 | 09:17 PM
martinmilne's Avatar
martinmilne
How do I check ? I have swapped relays with spares I had there the 2 yellow ones I think ? Still no joy if I bridge the relay it will work but it doesn't prime just stays on constant ? Any wiring diagrams or simple tests I can do thanks
Old Jul 28, 2015 | 12:31 PM
mentalasanything's Avatar
mentalasanything
Here's a hand drawn diagram:
You will see that the output of the Fuel Injection Relay (87) provides a positive to one side of the coil of the Fuel Pump Relay (86). The negative coil terminal on the fuel pump relay (85) is controlled by the ECU. When both coil terminals on the fuel pump relay are correctly charged, current can flow from the supply (30) to the pump (87).
Lee
Old Jul 28, 2015 | 03:33 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
Just to add to Lee's diagram...
Fuel pump relay is the silver one in the middle row up to the left of the yellow (sometimes Red) injection system relay.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
carlo
24
Oct 5, 2015 08:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
