6 degree exhaust mod
Old Jun 19, 2015 | 02:20 PM
BRAMMER's Avatar
BRAMMER
Default 6 degree exhaust mod
As title really is the exhaust needed to be modded at all when fitting 6 degree beam - I'll be fitted a supra diff at the same time and that makes the rear section sit lower so wondered if I'm going to run in to issues
Old Jun 19, 2015 | 04:47 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I've been told by Mark not to get my exhaust system made till after my beam has been done so yes
Old Jun 19, 2015 | 07:08 PM
Ridgey's Avatar
Ridgey
I,ve got 6 Deg and supra diff fitted and yes it will need modding.
My centre box is quite long and is rattling on a trailing arm adjuster, so I,m going to get the centre box moved forward 3" so it's in front of the beam and arms.
Also where it comes under the front mounting point of the diff, I had an inch sized area hammered in (down) 10mm, to stop the top of the exhaust pipe rattling on the countersunk Allen key bolt head.
Old Jun 19, 2015 | 10:51 PM
BRAMMER's Avatar
BRAMMER
Can anyone recommend anyone that can sort this out in the north of the country
Old Jun 20, 2015 | 08:42 AM
Ridgey's Avatar
Ridgey
Dave at BCS (St Helens) sorted mine.
Old Jun 20, 2015 | 08:47 AM
Caddyshack's Avatar
Caddyshack
Mark Shead sent my car up north to be done but cannot remeber who did it, he could tell you though.
I too had to modify for the supra diff but that was to be expected as mine is a pug. I also had to do a bit of hammering for the skyline box.
Old Jun 25, 2015 | 09:33 PM
Mike1's Avatar
Mike1
Hi Dave, what make of exhaust did you have or was it a whole new BCS system?
Was it much to have your system modded?
Old Jun 26, 2015 | 06:30 AM
Ridgey's Avatar
Ridgey
It was a blueflame I think that the BCS guys fitted a long time ago. Mods are done as favours
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
