Help please, fitting RS500 clocks in a saff
Old Apr 3, 2005 | 07:25 PM
JustinR's Avatar
JustinR
Default Help please, fitting RS500 clocks in a saff
I have bought RS500 clocks with the intergral boost gauge to fit in my saff. The problem is the connector is diffrent. I have source a connector but do i just cut off the saff connector and join the like for like colours together. Any help would be greatly appreciated as this is one of the last jobs to do before shes back on the road. Summer here!!!!!!!!!
Old Apr 3, 2005 | 07:36 PM
Niall.b's Avatar
Niall.b
Think its just a rubber or plastic pipe goes on the back. I just left mine disconnected & cut the pipe when i fitted the gauge in the vent hole. Just run the pipe through & connect onto the inlet manifold
Old Apr 3, 2005 | 07:41 PM
JustinR's Avatar
JustinR
The boost gauge i have sorted no problem, its the wiring connector that the problem. The 3 door clocks connector is diffrent from the saff
Old Apr 3, 2005 | 07:51 PM
westurbo's Avatar
westurbo
well i no its not the same but i put rs turbo clocks in my mates car and the connector wasnt the same.. but cut it and wired it up coulor 4 colour and it workd fine..... i think it should be ok m8.....
Old Apr 3, 2005 | 11:28 PM
cossied's Avatar
cossied
Default clocks
do you have a 4wd ? I fitted straight one into my 2wd no prob,
Kyle Langford
27
Aug 5, 2019 07:54 PM
mrmann
Aug 20, 2015 11:24 PM
Sultzi
12
Aug 16, 2015 01:08 PM
TIL13R
11
Aug 13, 2015 02:28 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
