Distributerless loom problems
Old May 25, 2015 | 12:34 PM
Escortdriver1's Avatar
Escortdriver1
Default Distributerless loom problems
Ive wired up the loom with the following instructions
Wire to pin 24 & 25
Then the confusing part..
Instructions to wire to the coil are sketchy and ive been told to use the "positive and negative part of the coil" but another set of instructions for a similar loom say "the 12v constant and the switched live" so contadict what the 2 wires to the coil actually are
After wiring up by instructions that the black / yelow was the switched live the black / yellow wire smouldered asif was been shorted.
What actually are the 2 wires on the coil and any ideas what can cause the wire to smoulder like this?
If anyone knows the voltage they should both have so i can make 100% there is no dammage to anything else too?
Old May 25, 2015 | 12:49 PM
James @ M Developments.'s Avatar
A wasted spark loom? Seems very odd instructions you have. If its Weber,
Triggers from the ECU to the ign amps are pin 25(std one) and pin 26
Coil pack has 3 wires, 2 outers are triggers from the two ign amps, the centre is an ign fed live, same as the ign amps.
pin 24 is the ign amp clean ground.
Tacho output if it has a driver in the ECU is usually pin 21
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Flateric_2002
Sep 15, 2015 08:41 AM
tib2220
Sep 14, 2015 12:33 PM
dms04
Sep 11, 2015 01:57 PM
