Cosworth ISCV top hat conversion
Old May 23, 2015 | 09:33 PM
Heitmann's Avatar
Heitmann
Default Cosworth ISCV top hat conversion
how do I go about modifying a ISCV for top hat ?
I have this kit
anyone done this ?
I know of the idle issues and so on, but have a spare valve i would like to try it on.
thanks
Old May 23, 2015 | 09:36 PM
robvirgo's Avatar
robvirgo
is this for anti lag use, had a few but passed them onto to someone here, sonic i think,races a black 3dr
Old May 23, 2015 | 09:38 PM
botters's Avatar
botters
competant bodger
best running a seperate valve for antilag that way you can have it proper agressive and still maintain some idle capabilities i believe the most common used ones are old vw ones i have a porsche 944 in at work at the mo that has one that looks suitable
Old May 24, 2015 | 04:35 PM
pectelboy's Avatar
pectelboy
You have to strip the iscv down and swap the shaft
Old May 24, 2015 | 05:53 PM
Heitmann's Avatar
Heitmann
Yes - I did come to that conclusion - but could you in anyway guide me? - I don't see how I can remove the old shaft
thanks
much appriciated
Old May 25, 2015 | 11:12 AM
MK MOTORSPORT's Avatar
MK MOTORSPORT
thanks
much appriciated
Hi
You dont remove the old shaft if you did what would you replace it with lol
You drill and tap it then screw the long cap head in to that with that hat on it
Mark
Old May 25, 2015 | 07:31 PM
Heitmann's Avatar
Heitmann
Originally Posted by MK MOTORSPORT
Hi
Mark
just googled "long cap head" lol that was the part i referred to as "shaft"
sorry didn't know the correct English word.
so how do I remove the original bolt, so I can drill and tap the shaft?
I can't seem to unscrew the original??
thanks
Kyle Langford
27
Aug 5, 2019 07:54 PM
Oct 9, 2015 07:38 PM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
fatboy billy
Aug 3, 2015 08:34 AM
