Has anyone ran big power on a linered 205 block?
Old May 6, 2015 | 09:28 AM
R4N SS's Avatar
R4N SS
Default Has anyone ran big power on a linered 205 block?
As above? What power did you get and was it reliable?
Old May 6, 2015 | 11:43 AM
Mark Shead's Avatar
Mark Shead
For a start why would you and what type liners are fitted.
Mark
Old May 6, 2015 | 01:04 PM
R4N SS's Avatar
R4N SS
i would rather a 200 block but been offered a fresh built 205 block engine with everything attached.
Just wanted around 450bhp and was thinking if it goes pop at this level then can i liner it and carry on?
I have a 200 block engine here - needing a rebuild, turbo, injectors, etc
I have other priorities i would like to spend my money on
Old May 6, 2015 | 02:21 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
I would sort out your other priorities 1st as a cosworth isn't worth jack compared to real life. Just my opinion mate. hope you are well
Old May 6, 2015 | 03:36 PM
R4N SS's Avatar
R4N SS
I am Rich, been working my ass off for a year now and want some sort of reward. If I can get the saph on the road for around 2k with a fresh built engine then its not all too bad and i havent spent a shit load by comparison - this is the reason why I will not be completing my 3dr build for a few years yet as I will never be happy unless its to the spec i want which is alot of money - also I want to do some of the work myself on it and that will only happen when i have more garage space
Will more than likely be sticking with stage3 setup for now so relatively cheap and reliable. I originaly spent a shit load on the saph when i built it 2 years ago so shouldnt need much more to put back on the road.
In the last year I have moved out, bought a golf diesel, a 3dr sierra and well on the way to reaching my deposit amount, just a tiny bit further to go. Am trying to do it with no help from my folks as i know they will be struggling when my old man retires later this year.
I have even quit as the Middlesex RSOC Treasurer as couldnt give it the time it needed due to work.
Good thing is work is super busy and im hoping they will extend my contract when its up in a few weeks or they take me on full time with the wage i asked for
Had some big client awards for a site I built for them and got loads of personal clients who need web dev work
Either way im in the best position I have ever been in so looking forward to the coming months.
Old May 6, 2015 | 04:40 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Fair play with work going well! Out of interest have you had any quotes to get your saff engine rebuilt? As that was a nice clean good spec saff before you took it off the road.
Old May 6, 2015 | 05:06 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Build your life before your car. The car can wait but your life cant. If you build up this 205 block to 450 you will be forced to drive it like Miss Diasy & that seems pointless. You sound as if you may be starting to take off work wise & you will have many years to build a car. Forget the I must build it now lark that way you wont achieve what you want. Ive had nearly 19 years of modded Cossies & I didn't buy a Cossie until I was 51. Life is a lot longer than you think at your age. However you cant do it the other way around build a great car then decide at 50 you need to start building for the 20 years of retirement . Its dull its boring & not what you want but few earn enough to have it both ways.
Old May 6, 2015 | 07:25 PM
StephTell's Avatar
StephTell
Wise words being spoken by Rod!
Although I'm not quite the fossil Rod is by now, I am old enough to lament the time and money I've wasted on cars, bikes and builds that I should have perhaps spent with loved ones, and on a solid future.
As Rod said, life is (hopefully) longer than it might seem, get your priorities right and make sure that you have a solid foundation to build on first!
Old May 7, 2015 | 09:11 AM
R4N SS's Avatar
R4N SS
Thanks for the wise words guys - it certainly helps put things in perspective
Andy, not even taken the head off that engine yet - im hoping it wont need much (famous last words ) but it can wait
Old May 7, 2015 | 12:59 PM
R4N SS's Avatar
R4N SS
Rod - whatever car i drive, it certainly wont be driven like miss daisy - i have no mechanical sympathy with these things
Old May 9, 2015 | 03:51 PM
3doorcozmess's Avatar
3doorcozmess
I'm in the same boat I'm just gonna drive until it gives out then worrie about it then. I've head of people running well over 450 and had no problems.
Old May 9, 2015 | 04:06 PM
lee2cossies's Avatar
lee2cossies
Realistically I think going from what iv seen over the years being on forums and into cossies, 400hp is about the safe limit some people have had more hp and they have lasted but I wouldn't fancy it! I'm in a similar boat with my Capri, I spent a fortune building a new engine on a 205 block, but then bought a 200 block! So for now I'm going to bolt a t38 on it and hopefully it will last for a bit at around 400hp.
Old May 9, 2015 | 04:10 PM
ajamesc's Avatar
ajamesc
You can get 200 blocks quite cheep if you hold on for one and look about. I got one from MT Motorsport for 500 quid.
Old May 9, 2015 | 04:14 PM
STeve's Avatar
Super Moderator
ask cossie4i as it did not end well for his 205
Old May 9, 2015 | 07:57 PM
james kiely's Avatar
james kiely
the thing is if you crack the 205 block you can pick them up for 150 quid so its not the end of the world if they give up
Old May 13, 2015 | 10:39 AM
3doorcozmess
500? When 3 years ago
Old May 13, 2015 | 11:28 AM
ajamesc's Avatar
ajamesc
about a year and a half ago
Old May 13, 2015 | 01:07 PM
R4N SS's Avatar
R4N SS
I still got a 200 block engine in the saph but also want a yb in the 3dr
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
3doorcozmess
Sep 15, 2015 06:06 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
ajamesc
Sep 8, 2015 06:51 PM
