Audi V6 3.0 tdi info
Old May 1, 2015 | 12:34 PM
TomPengelly's Avatar
TomPengelly
Kapow!!
Default Audi V6 3.0 tdi info
Does anyone know anything about 3.0 tdi's?
I have a 2007 Audi Q7 that has spun a shell and destroyed the crank and rod.
The engine fitted is a BUG engine code, i am having trouble finding a 2nd hand lump!
Does anyone know if an engine from a different 3.0 tdi model with different code will be the same (A6, A8, Q7 ect)??
Or what differences they do have if i found a different code engine?
But if it comes to it i may have to rebuild it if i can find a crank!
Old May 1, 2015 | 01:53 PM
stevos's Avatar
stevos
Vags are a bit of a mine field with engine numbers there are so many variations of them with engine blocks and cylinder head no.
I had an a4 with what was meant to be the better engine block number and best cylinder head no.
The car developed a small oil leak and upon inspection the engine block had a crack in it.
I really don't rate vag stuff much after reading up on all the problems you can have with them and for that reason I will never buy another one again.
Old May 1, 2015 | 03:28 PM
tony66's Avatar
tony66
Default vag
food for thought-the 3.o derv is touted as the best of the bunch-the old 2.5 and 2.7 were very "needy" in the repair and maintainance ...
i"ll stick with the bmw m57 i think..
Oranoco
12
Oct 2, 2015 02:18 PM
AJC
Oct 1, 2015 06:47 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
SMILER258
Sep 28, 2015 09:04 AM
