no temperature
Old Apr 26, 2015 | 03:16 PM
graham63's Avatar
graham63
Default no temperature
Temperature gauge on Mondeo 2004 tdci only moves when running it hard, gauge drops back when lifting off throttle, have changed both thermostats, can anyone help
Old Apr 26, 2015 | 03:49 PM
3i Jim's Avatar
3i Jim
10 Year Member
Could be the temperature sender playing up.
Old Apr 26, 2015 | 06:12 PM
cabriolet's Avatar
cabriolet
the obvious does the heater work is this the one with the pipe running under the engine that collapses
Old Apr 26, 2015 | 08:48 PM
graham63's Avatar
graham63
Thanks Cabriolet i will check this pipe, air con does work, doesn't get as warm as it used to
Old May 1, 2015 | 09:42 PM
Ecosport's Avatar
Ecosport
Have you checked your coolant level?
Derek Burleigh
Sep 16, 2015 06:27 PM
oilman
18
Mar 16, 2005 03:47 PM
foreigneRS
Technical essay Archives
Jul 20, 2004 11:44 AM
foreigneRS
Jul 20, 2004 11:06 AM
L33 BYT
Jul 6, 2004 09:25 PM
