Cosworth YB Standard engine max BHP
Old Apr 19, 2015 | 05:13 PM
damien roe's Avatar
damien roe
Default Cosworth YB Standard engine max BHP
I'm wondering what sort of power figures could I run with a standard cossie 4x4 engine I don't mind a turbo change etc to a T34 but will it work ok with a standard head
Old Apr 19, 2015 | 05:18 PM
Mark Shead's Avatar
Mark Shead
I have seen 468hp but I am sure 475hp is poss with a metal head gasket.
Mark
Old Apr 19, 2015 | 05:35 PM
costina's Avatar
costina
Live long and prosper!!
Mark
That is just mental Mark those BW turbos really do the business.
do you think it would make more say with a ab07 cam and hart inlet?
Also what exhaust manifold was it on?
cheers
Paul
Old Apr 19, 2015 | 05:36 PM
MrC's Avatar
MrC
T34 your looking at 380bhp, obviously bigger intercooler and uprated HG,
Old Apr 19, 2015 | 05:38 PM
MrC's Avatar
MrC
So what's the max without porting the head or any other uprated engine work??
Old Apr 19, 2015 | 05:42 PM
damien roe's Avatar
damien roe
oh that shocked me
the engine in question is 12000 miles after a rebuild with a group a gasket running sweet as a baby but only standard hp
Old Apr 19, 2015 | 05:43 PM
Mark Shead's Avatar
Mark Shead
cheers
Paul
With those parts and a 7670 I think you could get to 500hp. The turbo needs a non factory exhaust manifold.
Mark
Old Apr 19, 2015 | 05:44 PM
damien roe's Avatar
damien roe
mark these figures your talking are with a standard engine ???
Old Apr 19, 2015 | 05:49 PM
Mark Shead's Avatar
Mark Shead
470hp is easy on a good stock engine. With the changes the other poster asked about for the 500hp one.
The only change to a stock engine I recomend is a metal head gasket.
Mark
Old Apr 19, 2015 | 05:59 PM
MrC's Avatar
MrC
So those figures and it wouldn't go bang??
Old Apr 19, 2015 | 06:08 PM
Mark Shead's Avatar
Mark Shead
It should not if done correctly but you would be clearly pushing the motor hard.
Mark
Old Apr 19, 2015 | 06:34 PM
costina's Avatar
costina
Thank you Mark.
Paul
Old Apr 19, 2015 | 06:39 PM
Caddyshack's Avatar
Caddyshack
I have a std engine running exactly that amount that Mark mapped for me and put together the externals, it trashed the gearbox in no time but made the numbers. It is super responsive and almost feels slower than the laggy t34 I had due to the fast spool.
Old Apr 19, 2015 | 08:16 PM
damien roe's Avatar
damien roe
How would a t38 work on a standard engine
Old Apr 19, 2015 | 08:24 PM
Mark Shead's Avatar
Mark Shead
And you never ran it at full power wait until you turn the boost up
Mark
Old Apr 19, 2015 | 08:25 PM
Mark Shead's Avatar
Mark Shead
I have done 439hp on one on a stock engine.
Mark
Old Apr 19, 2015 | 08:35 PM
damien roe's Avatar
damien roe
so mark a t38 turbo and a hart inlet I should get 400bhp easy
Old Apr 23, 2015 | 01:47 PM
Caddyshack's Avatar
Caddyshack
Happy days if a hart inlet releases 60bhp. I do not think it will?
Old Apr 23, 2015 | 01:56 PM
Stu @ M Developments's Avatar
PassionFords Creator
A GOOD standard YB, a quality T38 and a set of decent injectors and strong head gasket will often yield up around the 450 mark.
The most I have seen on the dyno live mapping a T38 was 463 at 2.3bar but I suspect that was higher than standard compression as it also made unusually good low end power.
Old Apr 23, 2015 | 03:11 PM
costina's Avatar
costina
Stu i have maram shafted 34/63 can that be modded to 38 spec? Cos that sounds right up my street.😉
Paul
Old Apr 24, 2015 | 01:10 AM
Oz_RS500's Avatar
Oz_RS500
these power figures that are quoted, are the rear wheel hp or estimated flywheel hp?
Old Apr 24, 2015 | 07:01 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
I made 411bhp at the rear wheels with a standard engine. No head porting, no special crank or pistons. Just a GT30. A MAD inlet cam, a decent ecu and mapping and boost.
Old Apr 24, 2015 | 07:45 AM
Caddyshack's Avatar
Caddyshack
Dynoed flywheel, we tend to use fly here where as many other countries refer whp and I wouldn't bother with the debate, it has been done to death.
Old Apr 27, 2015 | 04:52 PM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
What turbo you got these days Damo ?
Old Feb 19, 2016 | 03:49 AM
Oz_RS500's Avatar
Oz_RS500
reviving this old thread.
What spec is this MAD inlet cam?
which BD cam is it equivalent to, or is it a completely different spec?
Old Feb 19, 2016 | 07:07 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
If everyone knew its Spec then it would not be a MAD Spec. I know from my own cams that Mark talks long & hard to a certain cam company getting exactly what he wants.
Old Feb 19, 2016 | 11:58 AM
natehall's Avatar
natehall
I often have people ask me the same question about some of my custom code I run on my websites. and my answer is the same, if I release it it would not longer be custom code
Old Feb 19, 2016 | 02:34 PM
Same here on our 320bhp conversion for the Fiesta 1.6 Ecoboost.
Random call from Tuner X.
"Hi Stu... we cant get more than 260bhp. What boost, spark advance and torque profile are you using? Are you desensitising the engine roughness tables? How do you get round the 1.6bar boost limits?"
Id be too embarassed to ask somethingh like that!
Old Feb 19, 2016 | 02:44 PM
Mark Shead's Avatar
Mark Shead
Radom call from Tuner X.
He will also tell his customers how great he is and how crap you arethis seems to be standard practice with most tuners
Mark
Old Feb 19, 2016 | 02:52 PM
Mark
Wouldnt it be lovely to work in an industry where tradesmen respected each other and just did their own thing?
Drives me crackers mate, so many dissrespectful backstabbing tossers in our industry.
Most of whom genuinely wouldnt pass my little 2 page tuning exam that I give prospective employees before they can open a customers bonnet here.
Old Feb 19, 2016 | 03:05 PM
Mark Shead's Avatar
Mark Shead
Totally agree.
Mark
Old Feb 19, 2016 | 04:55 PM
costina's Avatar
costina
So does that mean i cannot have your cam specs then Mark and those spark advance tables from you Stu?
Lmfao.
I get the same at work with joe public asking how we do things trouble is there is only so many ways to tell them to bring it to us.
At least now there are tuners like you both who do your own development work and turn out some cracking results. Unlike the days of copied dodgy chips.
Old Feb 24, 2016 | 12:46 AM
Oz_RS500's Avatar
Oz_RS500
HI Rod,
i understand your point, but it would be good to have a general idea as to lift and duration so it could be compared to other cam specs.
manuel boeckx
13
Oct 3, 2015 02:29 PM
IAN RS2k
Aug 18, 2015 07:51 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Aug 14, 2015 07:29 AM
