Rear door on focus locked will not unlock
Old Apr 5, 2015 | 11:19 AM
roger69's Avatar
roger69
Default Rear door on focus locked will not unlock
Help I cannot open rear drivers side door I have managed to remove door card with a bit of damage unfortunately but still cannot release lock had it motd but failed on locked door I need to get door open to get lock out but how anyone know
Old Apr 5, 2015 | 02:49 PM
st220kyle's Avatar
st220kyle
Have you tried with engine running? Had the same a few years ago on an old mondeo, when the engine was running the voltage was slightly higher and must have gave it that extra kick to get it working
Old Apr 5, 2015 | 05:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
remove the door card from the other rear door and see what could be causing the problem
you can get the wiring looked at as well but i suspect it will have failed either on the dead lock locked position or the little cable end has snapped off and so has stopped the door from opening that way
Old Apr 5, 2015 | 06:45 PM
roger69's Avatar
roger69
The wiring is OK checked the lock and unlock pulse wires both OK lock button is still attached OK to rod and lock,it has been playing up for awhile now when it locks it sometimes will not unlock for a couple of days sometimes I can unlock it manually sometimes not but now it will not shift so how do I get the damn door open to get the lock out.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
155lee
14
Aug 22, 2015 12:15 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Red_bull
Aug 9, 2015 08:34 AM
tankybaby66
Aug 9, 2015 07:13 AM
