Hart Inlet with Anti Lag Air By Pass ***SOLD***
Old Mar 17, 2015 | 12:55 AM
Sonic Boom's Avatar
Sonic Boom
Default Hart Inlet with Anti Lag Air By Pass ***SOLD***
Genuine Hart Plenum modified to accept a large air by pass for Anti Lag will also work for Idle Control.
Comes with a standard throttle body spaced out to 3" then ported comes with a PF09 and a ISCV alloy blank, throttle cable bracket and associated pipe work.
All ready to bolt straight on.
£500
Cheers Rich
Old Mar 17, 2015 | 03:48 PM
Caddyshack's Avatar
Caddyshack
What are the benefits of these over std 4x4...leaving aside the anti lag and is there a HP limit that these run to?
In the pic there is a tube near the throttle body about 22m diameter...is that the bypass and could it be used to run a servo for brake vacuum with a one way valve to stop boost pressure going the wrong way?
Old Mar 17, 2015 | 09:42 PM
Sonic Boom's Avatar
Sonic Boom
I believe these inlet are good for about 750 bhp, Rod or Mark Shead are the best people to ask as they took them to their limits.
They have a much better flow over standard plenum covers with equal amounts of air being delivered to each cylinder.
The 22mm tube is connected to the air by pass valve for the anti lag as it feeds air past the Throttle Body when it's shut.
Rich
Old Mar 17, 2015 | 10:02 PM
fraser9764's Avatar
fraser9764
tempting....
What are you changing to now Rich?
Old Mar 17, 2015 | 10:07 PM
Caddyshack's Avatar
Caddyshack
Thanks, I will see if I need it for my 530bhp build
Old Mar 17, 2015 | 10:11 PM
Sonic Boom's Avatar
Sonic Boom
Originally Posted by fraser9764
tempting....
Already changed mate I'm running a DBW throttle now
Rich
Old Mar 25, 2015 | 09:11 PM
Sonic Boom's Avatar
Sonic Boom
Bump
Rich
Old Mar 25, 2015 | 09:33 PM
turblower's Avatar
turblower
PM sent
Old Apr 3, 2015 | 12:13 PM
Sonic Boom's Avatar
Sonic Boom
Bump for the BH Weekend.
Rich
Brickhouse
14
Oct 3, 2015 07:28 PM
Fezman1
Oct 2, 2015 01:22 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
