zetec turbo or zvh?????
From: Newcastle-under-Lyme, Stoke-on-Trent, Staffordshire
Hi everyone I have everything off my efi turbo engine except the block I was thinking of building a zvh engine or should I do a zetec turbo conversion which is the easiest and cheapest option? Also which zetec engine should I use 1.8 or 2.0 and black top or silver top if I was to do the zvh conversion?? Cheers mark
personally I would go Zetec turbo! I would go blacktop 2.0l using all FRS stuff or you can use st170 bottom end (forged as standard) with 2.0l blacktop head and then FRS stuff.
I have two 1.8 silver top engines and a st170 engine. Why not a zvh? as I like the efi inlet which is cheaper to do?
Blacktop head Ł100
St170 bottom end Ł100 (u have 1 already)
Focus rs thicker headgasket Ł50
ARP conrod bolts Ł75
ARP headbolts Ł131
Subaru injectors Ł50
Focus rs inlet manifold Ł30
Then use your manifold, turbo etc
ARP headbolts Ł131
