zetec turbo or zvh?????
Hi everyone I have everything off my efi turbo engine except the block I was thinking of building a zvh engine or should I do a zetec turbo conversion which is the easiest and cheapest option? Also which zetec engine should I use 1.8 or 2.0 and black top or silver top if I was to do the zvh conversion?? Cheers mark
Zetec turbo.
personally I would go Zetec turbo! I would go blacktop 2.0l using all FRS stuff or you can use st170 bottom end (forged as standard) with 2.0l blacktop head and then FRS stuff.
Whichever way you do it will cost you a few quid to do it properly.
Originally Posted by doga-ot
(Post 6568491)
Blacktop head £100
St170 bottom end £100 (u have 1 already) Focus rs thicker headgasket £50 ARP conrod bolts £75 ARP headbolts £131 Subaru injectors £50 Focus rs inlet manifold £30 Then use your manifold, turbo etc |
(Post 6569147)
Blacktop head £100
Originally Posted by mondeomark
(Post 6569169)
What about doing a zvh using the st170 bottom end?
At the end of the day its your build and your decision what way you go with it good luck bud
© 2024 MH Sub I, LLC dba Internet Brands
