Odd problem since service
Old Feb 15, 2015 | 11:33 AM
KW-rscos's Avatar
KW-rscos
Default Odd problem since service
Did a quick service on my R reg 1.6 escort Zetec the other day (plugs, oil, oil and air filter) and now when I start it the revs rise to about 1.5-2k for a minute or so before settling back to normal. It also stinks of running rich, what could it be????
Old Feb 15, 2015 | 03:06 PM
stevos's Avatar
stevos
Did you plug the air flow meter back in.
Old Feb 15, 2015 | 03:29 PM
KW-rscos's Avatar
KW-rscos
Yeah checked that, even took all ignition plugs off and checked them after
Old Feb 15, 2015 | 04:37 PM
stevos's Avatar
stevos
Idle controll valve could be faulty.also check for air leaks.
Old Feb 17, 2015 | 12:20 PM
gcfcos's Avatar
gcfcos
Put the old plugs back in and retry it see if still the same. Stranger things have Happened
Old Feb 17, 2015 | 12:29 PM
RichieST's Avatar
RichieST
What plugs did you use? I've found zetecs can be fussy buggers if you use cheaper aftermarket ones. I would always stick with gen ford ignition components.
Old Jun 24, 2015 | 10:11 AM
gcfcos's Avatar
gcfcos
Did u ever sort it?
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
dms04
Sep 11, 2015 01:57 PM
truffleshuffle
Sep 10, 2015 09:35 PM
routemaster
Sep 7, 2015 05:27 PM
fuzzy
Sep 4, 2015 10:11 PM
