Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Recommendations on rivnut kits
Old Feb 4, 2015 | 09:02 PM
Gaz 88's Avatar
Gaz 88
Default Recommendations on rivnut kits
Looking at getting a kit to set rivinuts as got a few jobs on my shell that require them!
I only want a budget kit as it will only get minimal use but don't want rubbish.
Also have seen some that require a notch in them? But most don't.
Old Feb 4, 2015 | 09:29 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Cheap = Rubbish
I have this one: http://www.memfast.co.uk/shop/vclose...cat=2258004632
Uses socket cap bolts to pull inserts in, easily replaced if broken/damaged (spares included).
Old Feb 5, 2015 | 03:10 PM
dug112y's Avatar
dug112y
passionford pro
^^^^^ what he said
Old Feb 5, 2015 | 04:31 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I paid about Ł70 for a gesepia one about 10 yrs ago, I have used it loads and is very good.
Old Feb 5, 2015 | 08:21 PM
Gaz 88's Avatar
Gaz 88
Originally Posted by Richie.
Cheap = Rubbish
Do you just tighten them up with a spanner with that kit?
Cheers everyone.
Old Feb 5, 2015 | 08:30 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
On my one you drill the hole and the fit the riv nut in the tool and squeeze like a rivet then unscrew the tool and you are done.
Old Feb 5, 2015 | 08:44 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I've an eclipse and a blue point one
The work shop has a sealy one all work just as well as each other
Old Feb 5, 2015 | 09:12 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Cheers everyone.
Yeah....simples
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
