Sierra 90 remote control for central lock installation
Old Nov 17, 2014 | 04:47 PM
foortia's Avatar
foortia
Default Sierra 90 remote control for central lock installation
Hey, does anyone know how can i installate the remote control for locks? I heard that remote control system can be attached straight to one door's motor?
So I opened little bit right front door and I found four different wires going to motor: red, brown, yellow and white. I found old topic for this and someone said that yellow is closing and white is opening (or other way). Do you guys know about this? What to do with brown and red wire?
Next I did this, I did cut white and yellow wire, and i connected them to each other and all locks closed, then I connected them other way and all locks opened. So it must be possible to control from here right? Next I bought remote control system, and now I dont know how to connect this.. I have burned two fuses so far
http://tinypic.com/r/xwns8/8
How to connect the wires according to that? That picture of coupling came with the remote system.
Thanks guys!
Old Nov 18, 2014 | 05:35 PM
foortia's Avatar
foortia
Okay wires at car:
red = +
brown = earth
white=open
yellow= close
this is what i found out from old posts around the world.
I did next this.
Car + (red) to box's red (+12v) down left at picture. Car earth to black, down right at picture. I measured from the box that if i press "open" from key, blue wire will get +12V, and if i press "close" green wire will get +12V. So blue to white wires and green to yellow wires. When I closed the loop by installing the fuse, locks started immediately to turn off, on, off, on and so on.. So I tried to lock them using remote and fuse burned... HEEELP!!!
Old Nov 20, 2014 | 07:15 AM
foortia's Avatar
foortia
Okey I opened the box and there are these writens in the circuit
first line
Red=+12V
Green=Lock
Blue=Unlock
Brown=flasher
Brown=flasher
Pink=trunk
Red=trunk
Purple=+12V
second line
Black=Ground
Brown(Not there, no wires)=K2
Brown)=LK_CHK
White(not there, no wires)=K1
Yellow=UNL_CHK
Green=windows
Orange=windows
Black=ground
And I connected red +12V to cars red which is +12V and black to cars brown which is earth (-). Then I connected Green(lock) to cars yellow(lock) and Blue(open) to cars white(open). And locks starts immediately run open,closed,open,closed. When I press lock from remote, fuse burns..
And here is the wiring diagram for the car locks, Red is +12V and Br is earth(-). Y=yellow wire and W=white wire.
Can someone help !
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
yorkie92
Sep 6, 2015 05:34 PM
