Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
MK1 Focus 1.8 TDI Heater Problems
Old Nov 12, 2014 | 10:34 AM
dazza2471's Avatar
dazza2471
Default MK1 Focus 1.8 TDI Heater Problems
Hi guys my trusty old focus has just developed a heater fault that i need some help with. It only blows out luke warm heat when you are driving but when stationary it is vertually cold. Temp gauge sits in the middle and i have noticed that after driving for a short while the radiator fan comes on. Coolant level is as it should be and its not losing any. Any ideas would be greatly appreciated. Thanks
Old Nov 12, 2014 | 12:30 PM
RichieST's Avatar
RichieST
Fucked water pump or a blockage in the system gets my vote. Don't believe the temperature gauge they sit bang in the middle between 60 and 100 degrees so may well be overheating.
Old Nov 13, 2014 | 12:24 AM
Colin_P's Avatar
Colin_P
As above but I'd add the thermostat to the list.
The engine temperature sensor is not a water sensor on these, instead it is a metal to metal sensor and sits in a blind hole in the head.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
taylora1409
Aug 12, 2015 12:06 PM
