Crankshaft sensor focus 1.8tdci (Not camshaft sensor}
Old Nov 7, 2014 | 10:40 AM
wiganer's Avatar
wiganer
Default Crankshaft sensor focus 1.8tdci (Not camshaft sensor}
Can someone tell me where i can find the crankshaft position sensor on a 1.8tdci 2003 ford focus preferably a diagram or picture also. i have lifted the airbox because i thought it was under there but i cant find it.
Old Nov 7, 2014 | 10:59 AM
wiganer's Avatar
wiganer
And while we are on the subject of crankshaft senseor, do i simply unbolt the old one and put the new one in its place or is there anything special i need to do?
Old Nov 10, 2014 | 08:56 AM
wiganer's Avatar
wiganer
Does anyone know the answer or is this forum dead?
Old Nov 10, 2014 | 05:43 PM
Harryh24's Avatar
Harryh24
think it's underneath goes into the bel housing and yes change old for new job done.
Old Nov 10, 2014 | 06:04 PM
chris cdti's Avatar
chris cdti
On the back of the engine above the RH driveshaft. Its held on by a 8mm bolt from memory. But the tdci version has slight adjustment so it does not foul the flywheel.
Old Nov 11, 2014 | 02:45 AM
wiganer's Avatar
wiganer
Thanks guys....slight adjustment, slightly worried, how vital is this.
jessie_rs
62
Aug 6, 2019 09:27 PM
mike elsome
Sep 14, 2015 04:08 PM
Marino
Sep 12, 2015 11:10 AM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
