Fiesta Mk6 & Mk7 - wheels interchangeable?
Old Nov 2, 2014 | 10:10 AM
MJK 24's Avatar
MJK 24
Default Fiesta Mk6 & Mk7 - wheels interchangeable?
Are the 15 inch steel rims fitted to Mk6 and Mk7 interchangeable?
Ford website is showing different part numbers for the 6J x 15" steel rims for the Mk6 and Mk7. Is the offset different or something?
Any help much appreciated!
Old Nov 2, 2014 | 10:21 AM
3i Jim's Avatar
3i Jim
10 Year Member
Mk6 are 4 stud, mk7 are 5 stud I think.
Old Nov 2, 2014 | 10:52 AM
MJK 24's Avatar
MJK 24
I think the lowered powered ones at least are 4 stud. There's a 11 reg over the road with four strut wheels on.
Old Nov 2, 2014 | 05:01 PM
Dal_'s Avatar
Dal_
There aren't any 5 stud Fiestas.
The Mk6 Fiesta ST has ET52.5 alloys and the newer one is ET47.5 so probably not much in it really. (Both are 4 x 108)
The differences are probably just the offset as you mention. If you can get a definitive answer as to what the offsets are on that website, then you can judge whether any differences will matter. (doubt 5mm would make much problem if the 15" steels have the same ET as the ST versions)
Old Nov 3, 2014 | 07:59 AM
XR2's Avatar
XR2
Exactly. MK6 wheels had a very low ET. So using them on a MK7 Fiesta they might rub or touch the shocks.
And: ALL Fiestas had 4x108. No matter if they came with 40 or 180 hp.
Old May 13, 2017 | 05:56 PM
Lewis Lucas-Plowman's Avatar
Lewis Lucas-Plowman
Hi I have a Ford Fiesta mk6 2003 and I have bought some alloys and was wondering if ET35 will fit as I am now worried they won't
Old Jan 8, 2026 | 05:30 PM
Mikewoods74's Avatar
Mikewoods74
Default Different offset
the mk7 calipers wont allow mk6 alloy wheels to fit, ive tried putting mk6 alloys on my mk7 but the offset is different
JoeyBoyden
Jan 4, 2024 02:36 PM
Kyle Langford
27
Aug 5, 2019 07:54 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
23
Sep 12, 2015 12:56 PM
