S2 fuelling issue
Old Oct 17, 2014 | 06:39 PM
rsmog33's Avatar
rsmog33
Default S2 fuelling issue
Hi guys. My s2 still wouldn't start due to fuelling issues. Had to hold metering flap down to get it going.
Then I crimped the hose from the oil separator to metering unit while my mate cranked it over and it fired up first time.
So I blocked this off and now vent to atmosphere through a mini k&n filter.
Does this mean I have basically overcome an air leak engine side so now the flap has enough vacuum to pull down and send fuel through???
Starts first time now and runs sweet!!!!
Old Oct 18, 2014 | 06:14 PM
rsmog33's Avatar
rsmog33
Anyone?? Would be great for opinions..
Old Oct 19, 2014 | 10:59 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes exactly that.
Old Oct 19, 2014 | 01:28 PM
rsmog33's Avatar
rsmog33
Originally Posted by Karlos G
Yes exactly that.
Great thanks, thought as much. However when I said it runs sweet that is a slight porky
It is now slightly overfuelling but I think that is to be expected when changing the breather set up. I am using auto specialists oil separator.
Is it safe to say that with a decent set up now on the fuelling things should be ok?? Engine seems much happier without the vapours going through the metering unit as it is quite heavily modified so does breathe a bit harder.
Old Oct 19, 2014 | 03:23 PM
Piston Broke's Avatar
Piston Broke
Im a bit lost, you on a baileys system i guess on the oil separator ? so the bottom pipe to the metering head, you capped of the metering unit and put a K&N on the bottom of the separator ?
Old Oct 19, 2014 | 04:37 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Often the case if there was previously a vacuum leak, I would recommend a setup yes mate.
Old Oct 20, 2014 | 07:10 AM
rsmog33's Avatar
rsmog33
Thanks Karlos. I noticed from reading other threads that you seem to favour blocking off the metering unit form the breather also.
What is your set up with the breather pipe now from the oil separator?? Do you have a catch tank ( or similar ) or do you vent straight to atmosphere??
I have merely attached a small breather filter to the end of quite a long samco oil resistant hose and let it vent down near the front anti roll bar.
Seems to be different views on catch tanks etc..and also fumes generated. Mine seems ok at the moment. Cheers
Old Oct 21, 2014 | 09:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes because it eliminates fuelling issues if you have a leak, I vent to atmosphere, no engine on the planet prefers dirty oily air to fresh! lol
Old Oct 21, 2014 | 09:48 PM
rsmog33's Avatar
rsmog33
I couldn't agree more. Do you use a catch tank or vent through a mini breather filter to atmosphere???
Old Oct 21, 2014 | 10:25 PM
Piston Broke
But the part i dont follow is, wont it kill the vacume. ie like when you remove the oil cap it kills the engine ? so by putting a K&N on the baileys tank or whatever make isnt it just like doing that ?? thanks, just intrested
Old Oct 23, 2014 | 09:06 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No, because you have blocked the metering unit return off.
Old Oct 23, 2014 | 09:24 PM
Piston Broke
this the tank with the 2 x rocker vents at the top and one to the metering unit at the bottom ? the bottom is the one you would K&N then ?
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
pabloXR
Sep 21, 2015 12:42 PM
