ib5 gearbox for our s2
Old Oct 16, 2014 | 07:02 PM
luxembourgrst's Avatar
luxembourgrst
Default ib5 gearbox for our s2
well
I looked around on the Net and I found out that the ford KA 1.3 have the nearlyest gear ratio that our escort rst s2 ? is that true?
but there are some ka gearbox with front starter housing and some with back starters
we need the front starter housing for our CVH
is it a good choice the ib5 from the KA
and than only have to fit the LSD from the s2 in it ? is it a big job
thanks
Old Oct 16, 2014 | 07:06 PM
studabear's Avatar
studabear
The clutch is hydraulic on the ka so a hydraulic conversion would be required, or you could find a mk5 escort front starter ib5 and have ka gears and s2 lsd fitted into it.
Old Oct 16, 2014 | 07:29 PM
luxembourgrst
hmmm yes I saw well no I d ont want hydraulic clutch
I also saw the installation of the gearbox make the engine higher need to drill the brackets.....
is ther no an other gearbox escort mk5 mk6 (NO hydrolic) with 95% same gear ratio like rs turbos
Old Oct 16, 2014 | 09:50 PM
HaggisTurbo's Avatar
HaggisTurbo
You definitely sure you dont want to go hydraulic? The pedal is a lot lighter and not as hard as you would think, There is a guide in this forum for doing the conversion by Karlos G
Old Oct 17, 2014 | 09:03 AM
XR2's Avatar
XR2
Changing from BC/B5 to IB5 won't have any effects on the position of the engine!
There were to '95 Escorts with front starter IB5 boxes:
1.4 PTE (late CVH multi-point EFI type)
some of the early 1.6 16V Zetec ones
Both have shorter overall ratios than the S2. Ratios are nearly the same like the S1 had.
You can use one of these boxes with the shorter ratios, or you swap the internals with any other IB5 ones you'd like more or you do a hydraulic clutch conversion.
Old Oct 17, 2014 | 09:08 AM
luxembourgrst
This looks interesting it s mean i need a escort mk5 1.4 efi box and than fix thé s2 lsd in it without hydralik pedal std fix on it
Old Oct 17, 2014 | 09:18 AM
XR2's Avatar
XR2
When we talk about
Escort MK5a (91/92)
Escort MK5b (93/94)
Escort MK6 (95on)
Then you're gonna need a MK6 box. IB5 boxes were available from about 95/96 on.
I'm not sure if you can just fit the S2 diff with LSD into the box. But if this is a yes, the ratios of the 1.4 box combined with the S2 diff will give you nearly the same ratios like the standard S2 had. With slightly shorter first three gears.
Old Oct 17, 2014 | 09:08 PM
GINGExR2 T's Avatar
GINGExR2 T
I've just fitted an LSD S2 diff to an IB5 box, not 100% sure of what car it came from, but it's front starter, cable clutch, 3.82 final drive and the LSD fitted straight into the crown wheel. There is an ID tag still on the box that I can get tomorrow if needed.
Oh yer, and it has the S1 type front casing mounting point so will fit S1 or S2 Escorts.
Ginger
Old Oct 18, 2014 | 02:18 AM
luxembourgrst
I found one buts is from a 1.4
FORD Escort VI (GAL, AAL, ABL) 1.4 55 kW 75 PS (01.1995)
KBA: 0928852, 2028355, 7528385, 8566312, 8566324
OE-Nummer: 96WTBAAF0B5K130
http://www.ebay.de/itm/402218-Schalt...item2325602d36
but what sa the ratio of the 1.4 ones? similar to S2
Old Oct 18, 2014 | 06:39 AM
mattxr3i's Avatar
mattxr3i
What are mk6 Escort 1.3 ratios like?
Old Oct 18, 2014 | 07:12 AM
luxembourgrst
can this be true?
some info
1.25/1.4 and 1.6 Zetec S Gear Ratios were found to be as following:
1st 3.58
2nd 1.93
3rd 1.28
4th 0.95
5th 0.76
The 1.7 Puma box however has a slightly taller 1st gear and a closer 3rd, 4th and 5th gear:
1st 3.15
2nd 1.93
3rd 1.41
4th 1.11
5th 0.88
The 1.6 Zetec S, has a 4.25 Final Drive Ratio
The 1.25/1.4, has a Final Drive Ratio of 4.27.
The 1.7 Puma has a Final Drive Ratio of 3.82
Escort RS turbo S1 ------------------- 3.15 1.91 1.27 0.95 0.76 4.27
Escort RS turbo S2* -------------------3.15 1.91 1.28 0.95 0.76 3.82
it s mean only the 1 st and second gear change is it a big difference?
Old Oct 19, 2014 | 11:10 AM
Karlos G's Avatar
Karlos G
Balls Deep!
It will if it's a Sport or Street Ka IB5, the casing is offset.
Old Oct 19, 2014 | 04:38 PM
luxembourgrst
yes I saw it in your threat with the pics inside that you hade to modif ....
I have one mk5 escort ib5 (front starter and NO hydrolik clutch) but it s from 1.4 engine
and I don t realy no the gear ratio and it is a good idea to fit it of curse with the s2 LSD
Old Nov 2, 2014 | 05:02 PM
luxembourgrst
well took my rst2 box apart
the LSD
and her is my IB5 gearbox from a escort mk5 1.4 engine
(NO hydrolik clutch and front starter )
only want to know what is this plastique ?reverse gear sensor? and where or how I fit my rst2 loom for the reverse sensor ???
and what is this plastic again?
what about the release bearing I use this flat one? because I have a brand new AP organic 2008 clutch with his relase bearing but is not flat wich I can use?
Old Nov 2, 2014 | 06:13 PM
xrmalin's Avatar
xrmalin
I'm not sure what the first plastic bit is but the second is the gearbox breather
Old Nov 2, 2014 | 06:36 PM
luxembourgrst
well I searched a little bit and I think I need to take the white plastic out and make a steel plate to cover it
and take the std S2 reverse sensor at put it where the big black imbus screw is on the left side where the braket comes
Old Nov 18, 2014 | 06:45 PM
luxembourgrst
hy I put new beareing on the LSD one big one one small on and put the ib5 crown on it with the 8 bolts.
and im rebuild the ib5 now
i put the box together and do not let the selector shaft move around if it moves you could end up loosing reverse (my friend did this so i paid extra attention to reverse) i actually used mole grips on the little selecto stub sticking out the box to make sure it didnt move,
but I didn't put it on reverse gear with the linkage
is it normal that the gear I very dificcult to put in with the syncro they need to turn onces... noo
Old Nov 22, 2014 | 08:52 AM
luxembourgrst
I just finished my ib5 gearbox put 2 new bearing on the rs2 LSD (only need to change one) the big one for the ib5
made a 5th gear puller who worked very good
the LSD
rebuild it don't forget the 2 clips and the magnet
and put with the finger the little stick who action againste the rear gear and rebuilt the box staying in neutral...
new gasket but I rebuild the first gearboxcast with only the new gasket without using the green silicon (wich don t dry) tork the bolt at 20 Nm I hope there won t be NO leak ....grrrr
then I bought this green silicone put one it but only one the 2 last gasket
finish
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
