Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
which exhaust manifold for a zetec
Old Oct 13, 2014 | 07:33 PM
mondeomark's Avatar
mondeomark
From: Newcastle-under-Lyme, Stoke-on-Trent, Staffordshire
Default which exhaust manifold for a zetec
Putting a 1.8 zetec into my mk4 escort which exhaust manifold should I use standard, four branch or st170? Cheers mark
Old Oct 17, 2014 | 09:06 AM
XR2's Avatar
XR2
Haven't seen a dyno test yet comparing an aftermarket Zetec manifold with the ST170 item. ST170 has too much bends for my taste, I'd go for a "normal type" four branch.
Old Oct 22, 2014 | 10:14 PM
dug112y's Avatar
dug112y
passionford pro
st170 manifold is good. depending on what gearbox and sump your going to use will dictate if your going to use it std or have to modify it.
Old Oct 23, 2014 | 11:45 AM
mondeomark's Avatar
mondeomark
Using a cvh gearbox what sump would I need iv bought a st170 manifold.
jessie_rs
62
Aug 6, 2019 09:27 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
Si B
Sep 12, 2015 06:49 AM
