what next step engine modif
hy her is my spec
still MFI:
piper cam 285 t
group a coil
mongoose exhaust
big airtec intercooler
stage 2 turbo (set to 17 psi)
turbosystem chip (max 18psi)
ingnition advance 16 degree
have 190-200 hp normaly
next step im thinking about stage 3 burton big valve head ?? good idea?
a uprated clutch ?? wich one ?AP organic?? ( is there not one clutch wihtout changing pedal box? )
andim looking about a stage 1 cts gearbox or (ib5 with rst lsd ) good idea?
thanks
still MFI:
piper cam 285 t
group a coil
mongoose exhaust
thanks
i thought the degree would be lower if the engine is running more more power etc, not 16 etc, my car is bog standard and it was setup with 13 degree.
i might be totally wrong just threads I've read and picked up on, don't shout at me though lol
A stage 3 T3 would be your next upgrade for more BHP if your MFI can cope, around 240bhp is the limit of the rods though so be careful, even less if you bounce around the limiter a lot, many have broken them sub 200bhp!
ok thanks well stil have tandad piston and standard rods
well ok next step cylinder head stage 3 from burton..
what about the clutch ap organic? is there not an other one without changing the pedal box
You haven't set up your ignition timing with detonation detection yet did you? I would go for max advance of ignition. You need detonation detection and on rollers would be the easiest. If you never done it you need help -> Tuner
You don't need Stage three head! If anything it will make it worse to drive 😂
You only need ported and polished head for good gains.
Then add a hybrid T3 Turbo (Stage 3)
200bhp+ easily
Then Mfi and internals are holding you back
but why a satge 3 turbo? because my stage 2 can go up to 20psi
but I only run it a t 17-18 psi because my turbosstem chip limit to 18psi
a stage 3 can go up to 25 psi (like burton says)
thanks guys
thanks guys
No you will not gain some bhp.
Stage 3 turbo will make more bhp at the same boost...... 18psi stage 2 turbo around 190bhp, 18psi stage 3 turbo around 230bhp.
I just bought a knock detontation LED alert monitor gonna instal it
paceo
Aug 27, 2015 12:45 PM
