Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Focus CDTI wont start
Old Sep 28, 2014 | 06:03 PM
liamthecoder's Avatar
liamthecoder
Default Focus CDTI wont start
I recently bought a 1.6 cdti focus, on inspection i found that someone had jammed the Positive battery terminal with a screw to hold it in place (was arcing), anyways i serviced the car and it started up first turn of the key, then it died /stopped running
now it wont even turn over, the immobilizer light flicks constantly (16 Flashes/Can Bus Fault)
i checked all the fuses and wires for fault then used autocom to read the codes which were u1900 Can Bus Error, and a code relating to invalid security data on the instrument cluster
the dash simply says ----- i currently cannot connect to the ecu atall but i can connect to the instrument cluster etc
any ideas?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Fordmad!
Sep 26, 2015 05:24 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
nick8saff
Aug 16, 2015 05:35 PM
saph in dorset
Aug 14, 2015 10:10 AM
