Thinking of putting a skyline box in ?
Hi lads I smashed my first mt75 4x4 box two weeks back the good old 3rd gear let go I'v got a spare box witch I'm in the proses of putting in but as my mate Rex has done lots of mt75 boxes I'm thinking over the winter cutting my smashed part off my box and welding it on to a skyline box I'v been told to use a r33 4x4 box . But has any one got any info if this is the right box to use and wot will I need to do as I beleve the box will need a pump wiring up to it any info would be fab . Thanks for you time ps I no I will have to cut my tunel up to get it in witch is not a problem .
do it, do it, do it is what I would say don't waste any money on the mt75 put that money towards the conversion and have a car you can abuse and not worry about.
they are very tough gearboxes, ive thrown 570 hp 480lbft at a stock r32 gtr box with loads of 3 second 0 - 60 pulls and never a problem.
you can also have fully adjustable 4wd by controlling the pressure to the 4wd clutch and easily run rwd aswell.
r32 boxes are push, p33 pull I think or the other way around lol
Thanks lads it was graham c
That told me he has the r33 box in his mk1
I think I will be doing this mod over the winter it will be going into my focos .
As we are talking about maybe doing this mod dose any one no of any skyline brakers as I'm going to need a bear box and the front and rear pops to get uj,s of them to have them put in my shafts
I think so yes, if the 4wd/abs fuse is pulled on an r32 there is no power out of the clutch at all, but with an r33 it wasn't as simple as that, I don't know if its pressure related or if there is some mechanical lock there but the 4wd wont completely disengage on an r33/r34 by disableing 4wd/abs.
martin will know, I had a 4wd fault on my r33 and the system wasn't engageing but it still applied 60lbft to the front hubs on the dynapack whereas an r32 will not it will just go 100% rwd.
r32
http://www.ebay.co.uk/itm/Nissan-Sky...item3f3c8d51d9
r33
http://www.ebay.co.uk/itm/R33-GTR-Sk...item4adb002809
they can suffer with synchros like any box but redline heavyweight oil does work wonders with a worn gtr box
the later r33 box is a better/stronger gearbox aswell.
I thought about this and by the time you buy all the bits get stuff made have the box reconed as it will more than likely need it as syncros go for a past time plus the boxs are a very slow change you will be into a oppliger gearkit price range and its strong fast changing and fits without all the issues of changing everything
Some very good pointers there lads about the opliger gear kit as I'v had one in my hands only last week as my mate Rex is putting one in his escort . The thing is it's aprox £2000 then it's got to be fitted so let's call it £2300 in one big hit witch I just can not aford as I'm just about to do the setelmont to my devors I'm going throw . So with the sky line box way it's £400 / £600 for the box I can cut the bell housing,s and get welded for and £30 I can mod the tunel so free my time and labour over the winter free I will be onist I'm 100% I can get one in the car and working for under £1000 and if the box need a over hall I will get it done when I can aford it . Don't get me rong lads I would love to just do the bolt and play way but I just don't have the ££ to had with this devors
I can see ware your coming from but I was a tool maker and i still have a lath and a miller and i all so made jigs for a living so all it's going to cost to do the bell housing is the welding .
But as you have all said I will sit down and have a think about it but I still think I will be doing it . As at the end of the day I'v built a focos 4x4 my self shell mods the lot . I will keep you updated on wot way I go
with a lot of time if you cut the flange off your old box and get the box lined up perfect and marked all you need to do is get it welded on.
make a gearbox mount fit would be easy enough to make out of both mounts. propshafts can be altered for not a huge amount of money, you will have control over the 4wd aswell.
just the clutch to sort then which will need to be hydraulic converted.
id say if I wanted to do one I could do it for about £1500 but that would be me doing most of the work myself.
but if you don't have the ways/means to do it all yourself it would probably end up cheaper to do what jay has done for £2300
You have to ask why you are doing it, for me it was active center diff and the availability of cheaper gearkit conversions.
I made all the bits for mine, cut, welded, milled, box rebuilt/props/hydraulics etc and its cost me approx £1500+ all i bought was the main components.
I have a few more fancy bits than most on it but budget at that price if you doing it yourself and expecting it to work.
I see no advantage in doing it and not controlling the center diff correctly.
Exactly I still wouldnt fit a box standard box as there strong enough for power but 48 kilos heavier iirc very slow changing but its up to you , if i had the cash i would be buyig a oppliger sequential box now lol
Still doesn't get you the advantage of active center diff though.
good point jay, ideally it would need the attessa pumps unit with it then use this controller
http://www.google.co.uk/url?sa=t&rct...mgRLSguIS_uBKw
fully adjustable 4wd then and also self adjusting through an accelerometer and giro thingy bob
lolin all honesty though where do you stop then the diffs will need sorting for big power, its one of the reasons I went to the darkside as an old rb gtr will take 600 hp all day long on stock gearbox and diffs
Well you no I had a midnight purple 33gtr stage 2 and my 500bhp gtst and preffered the gtst as the engine was more torquey and like you say the 4ed system takes a battering it still felt a little out of touch with the driver lol and sapped power
The controller was the single most expensive part.
Like most people would spend 10k on an engine but crib at 5k for a box on here.
box 400-500
spinner plate 230+vat
welding 400-500
front prop50
gearbox mount 50
rear prop mines fancy 250
center push clutch depends wot you use 130-200 quid
pump for box 100
plus pipes and controlers martin dose one for 250
but you can do it cheaper like me
not cheap conversion but when i did mine no other boxs are good for 500 hp
welding 400-500
front prop50
gearbox mount 50
pump for box 100
Any specifics on the exact kit id need for my 4x4 or a link please mate been looking at gear kits i cant fibd one for that money
thanks in advance
a touch over £1500 at current exchange rates, fingers crossed my house extention and work doesn't take all my money.
r32 gtr gearbox £250
http://www.gtr.co.uk/forum/299073-r3...x-50000km.html
I know what id be doing, and having a rwd switch aswell
ive had 3 rb26 gtrs and all the gearboxes have been very tough, they get a lot of stick aswell with 600+ up em being hammered and 0 - 60 in 3.2 seconds ive done on a stock r32 box
and they will take it well
and they will take it well Last edited by scoooby slayer; Sep 29, 2014 at 05:04 PM.
The oppliger sequentials are big bucks and straight cut only so might be a tad much for road only. The close ratio ones in the long box are supposed to be much better suited to Cossie power as the Cossie was quite long (some would say over geared) from the factory.
did you see the kits in the link jay posted they seem very reasonably priced no?
