2002 Ford Mondeo 2.0 Ghia heats up
Old Sep 20, 2014 | 05:44 PM
Ricardo Gidon's Avatar
Ricardo Gidon
Default 2002 Ford Mondeo 2.0 Ghia heats up
Hi,
I own a 2002 Ford Mondeo 2.0 Ghia.
I try to do all the fixing by my self.
I have this problem that I am unable to fix for a while now.
The car heats up when I STOP. I have to push on the gaz in order for it to cool down abit and that does not always work.
Here's the thing! I have replaced the:
1) Radiator
2) Thermostat
3) Water pump
4) all tubes plus coolant reservoir tank
No water is missing. No oil is missing.
the car still heats up.
I am frustrated.
please help.
Old Sep 20, 2014 | 07:27 PM
tony66's Avatar
tony66
Default temperature
have you changed the actual temperature sender-or checked the actual temperature of the coolant...? it may not be overheating at all
Old Sep 20, 2014 | 07:52 PM
Ricardo Gidon
The temperature gauge is smack in the middle as it should be but only for the 1st 20mins so I assume if it shows the normal temperature at 1st it shows the overheating correctly as well.
Old Sep 20, 2014 | 09:11 PM
tony66's Avatar
tony66
Default overheating
not always-as the sender gets up to temperature it can misbehave-worth trying a new one for little expenditure-and or wire up a capilliary gauge to measure the actual temperature of coolant-or use a heat/temperature sensing gun
worth also checking if the cooling fan is turning the correct way-thats assuming it works as it should-if engine is genuinely hot it should be on trying to cool it
Old Sep 21, 2014 | 08:21 PM
Ricardo Gidon
I have checked the temperture. the engine is most definitely overheating.
however, I have noticed something which I think is weird.
There are little tiny bubbles climbing back into the reservoir tank. (kinda like soda)
could it be a compression lose?! causing the pistons to rise the temperature of the water?
Old Sep 22, 2014 | 06:34 PM
tony66's Avatar
tony66
Default bubbling
if its bubbling up it could be headgasket/cracked head/block etc
check for hydrocarbons in expansion bottle and go from there
borboyous
Aug 22, 2015 11:17 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
