Best gearbox?
Old Sep 10, 2014 | 07:59 PM
turbowag's Avatar
turbowag
Default Best gearbox?
Hi, I'm sure it's prob been asked before but what is the best gearbox to use on my Rs turbo, I'm gonna be running 250-280 Bhp so want to be able to cope with that sort of power, I'm still cvh so what is the most straight forward/ swap option? Also any other pointers/mods would be appreciated? Different 5th gear? Etc cheers
Old Sep 10, 2014 | 08:59 PM
BIL N KEL's Avatar
BIL N KEL
Cts do uprated boxes but think they're quite expensive compared to focus rs box conversion
Old Sep 10, 2014 | 09:00 PM
BIL N KEL's Avatar
BIL N KEL
I was quite lucky as the series one came with an uprated GEARS gearbox with better diff, big bearings etc already in it
Old Sep 10, 2014 | 09:44 PM
turbowag's Avatar
turbowag
Yeah I heard that had a good gearbox in it billy, u wanna sell it? Lol
Old Sep 11, 2014 | 01:43 AM
Chopshop85's Avatar
Chopshop85
IB5 out of a mk5/6 escort.
Ka 1.3 gearset
Use the FD out of the IB5 and fit the LSD from your standard box. This will give you slightly taller gears which I prefer, more sensible rpm at 70mph.
(If you want identical ratios you'll need to source a PUMA 1.7 FD and the lsd will need modifying.)
This is a direct swap, bigger bearings as standard, more webbing on the box making it stronger, and its not like most BC boxes which are 20+ years old and suffering from metal fatigue.
Old Sep 11, 2014 | 12:26 PM
turbowag's Avatar
turbowag
Thanks chop shop, exactly the sort of info I'm after, cheers
Old Sep 11, 2014 | 03:20 PM
turbowag's Avatar
turbowag
Some people say about the diesel gearboxes?
Old Sep 11, 2014 | 05:29 PM
Chopshop85's Avatar
Chopshop85
Diesel/petrol BC boxes are the same.
Just remembered as well, if you go for the IB5 box route, get yourself a puma gearlinkage as well. One of the best mods I've done to my car.
Old Sep 11, 2014 | 05:54 PM
mattxr3i's Avatar
mattxr3i
is the Escort 1.3 MK6 Gearbox the same ratios as MK4 XR3i?
Old Sep 12, 2014 | 09:37 PM
BIL N KEL's Avatar
BIL N KEL
Ka 1.3 gearset
That is what's in my s1 but with an uprated diff.
I'll find the reciept with the phone number bud. Pretty sure it was about Ł700
Old Sep 14, 2014 | 07:33 PM
martinmilne's Avatar
martinmilne
Any one do these already done to buy?
Old Sep 25, 2014 | 09:20 PM
marky_g's Avatar
marky_g
Fleet Manager
I'm looking into buying all the bits but seems like such a ball ach unless you know how to build a gear box, 3 old boxes just to make one good one if you got the time guess it's worth it
Old Sep 26, 2014 | 05:27 AM
marky_g's Avatar
marky_g
Fleet Manager
Actualy thinking about it what dose the gearbox need to come from mk6 escort with a CVH that's front starter?
Old Sep 26, 2014 | 05:39 PM
Chopshop85's Avatar
Chopshop85
Mine was labelled "mk5 escort diesel IB5" when I bought it off ebay.
Old Sep 29, 2014 | 09:49 PM
luxembourgrst's Avatar
luxembourgrst
what do you think about this gearbox http://www.gearboxman.co.uk/psgearboxes.html
is a stage 1 changing a lot ?
thanks
Old Sep 29, 2014 | 10:33 PM
Chopshop85's Avatar
Chopshop85
thanks
It says IB5 bearings and LSD.
Regardless of what it changes, its still a BC box which are 20+ years old and probably suffering from metal fatigue.
If you use an IB5 you already have those bearings (captain obvious) plus extra webbing on the bell housing to make the box stronger.
Old Sep 29, 2014 | 10:45 PM
HaggisTurbo's Avatar
HaggisTurbo
Ka 1.3 gearset
I opted for the full Ka 1.3 box and also bought a Ka starter to go with mine.
What revs should I expect from my car at 70mph? Is it gonna be horrendous lol
Old Sep 29, 2014 | 11:17 PM
Chopshop85's Avatar
Chopshop85
I'm sure there are calculators online you could find out. Obviously it depends on tyre/wheel size etc..
IIRC the ka 1.3 FD is 4.06, the standard rs turbo BC is 3.82
Old Sep 30, 2014 | 10:34 AM
luxembourgrst
It s mean is Not a Goodyear idea.to buy this stage1 gearbox?
Old Oct 1, 2014 | 07:17 AM
turbocabs's Avatar
turbocabs
so you use puma linkage is it right length any mods also whata bout drive shafts and clutch cable thanks
Old Oct 5, 2014 | 07:24 AM
luxembourgrst
what about the ful 1.3 kA box without the lsd from the rst ?
is it a good choice not to short
Old Oct 5, 2014 | 07:47 AM
Turbo Al's Avatar
Turbo Al
I've a mk5 escort 1.3 gearbox, is this the same as the ka?
Old Oct 5, 2014 | 09:44 PM
marky_g's Avatar
marky_g
Fleet Manager
Ka box is rear starter so need to be running a Zetec
Old Oct 16, 2014 | 08:20 PM
luxembourgrst
not all ka box are at the rear
Old Oct 16, 2014 | 09:46 PM
HaggisTurbo
Depends on the KA,
The early 1.3 Endura Ka's are Rear
Old Oct 19, 2014 | 11:27 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Sport and Street are front starter but the casing is offset and requires a lot of modding of the cradle to get it to fit correctly.
Better off using a casing that is already front starter and not offset (Escort Diesel van non turbo, MK5 Escort CVH IB5).
Old Oct 19, 2014 | 04:34 PM
luxembourgrst
yes I have one escort mk5 front starter (NO hydrolik clutch) but it s one from a 1.4 engine
and I don t no the gear Ratio ?
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
