Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
What tool is best for the job?
Old Aug 31, 2014 | 07:19 PM
Gaz 88's Avatar
Gaz 88
Default What tool is best for the job?
Hi
I want to cut some of the inner door skins off my track car to reduce weight what's the best tool for the job to get a neat edge? I have seen a small air reciprocating saw or a grinder?
Any ideas?
Old Aug 31, 2014 | 07:29 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
I would avoid the grinder sparks can burn anything and the dust goes everywhere too
air saw is ok, drill a pilot hole to get started, drill hole at each corner
I would use an oscillator, or air shears ,
all the air cutters use a lot of air, so a fairly big compressor is needed
Old Aug 31, 2014 | 10:39 PM
Gaz 88's Avatar
Gaz 88
I have just had a look at them are they like a dremel? And do they use a disc or blade?
Old Sep 1, 2014 | 08:53 AM
stu20004x4's Avatar
stu20004x4
mk6 escort fantasist
50litre compressor is plenty for an air reciprocator, and as said above less sparks and mess
Old Sep 1, 2014 | 10:15 AM
mk2grp1's Avatar
mk2grp1
machinemart do cheap air shears, kinda gun shaped
Old Sep 1, 2014 | 08:00 PM
Gaz 88's Avatar
Gaz 88
Cheers lads looks like I can get a 50 litre compresser and air shears for around Ł220
Old Sep 1, 2014 | 08:07 PM
mk1turboestate's Avatar
mk1turboestate
Just use a grinder with a 1 mm disc and a thick dust sheet to protect paint, gives a nice finish and is cheap, then finish it off with a flap disk if you want it nice a smooth, I have an air saw, air shears and most things you can think of but choose a grinder most times
Old Sep 1, 2014 | 09:37 PM
stu20004x4's Avatar
stu20004x4
Buy 2nd hand mate, i got a 50 litre compressor, 4x hoses, 2x impact wrench, 2x air chisel, 2x torque, 2x air sanders with loads of fittings etc, 200 quid!
Old Sep 1, 2014 | 09:54 PM
Gaz 88's Avatar
Gaz 88
Yer might start searching ebay! Cheers stu!
stevecfrst1
Sep 30, 2015 05:18 AM
Si B
Sep 12, 2015 06:49 AM
Rizlablue
Sep 6, 2015 09:58 AM
hopper350
Sep 4, 2015 12:53 AM
