Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
6.5 zs starting issues
Old Aug 10, 2014 | 01:57 PM
197gaz's Avatar
197gaz
Default 6.5 zs starting issues
Hi guys, noob here
Got a really frustrating fault with the other halfs zs
Petrol 1.6, 62k
A few times a week it struggles to start. Symptom is it'll fire, but feels like it runs in three, if you give it some throttle it cut out. Then if you go to start it again 99% of the time it'll fire no problems. It runs ok and never cuts out whilst driving.
So far I've replaced the plugs leads and coil pack. I've checked the battery which has failed its discharge as sometimes it sounds lazy whilst cranking, so I'm replacing that later today. Is there anything else to replace/check?
Pressure regulator/ cts
Gaz.
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
