Silvertop zetec oil pressure?
Old Jul 25, 2014 | 05:14 PM
Layland's Avatar
Layland
Default Silvertop zetec oil pressure?
What's the oil pressure that zetecs are meant to run at as my pressure seems high at 100 psi at 3000 rpm and think it's forcing oil through the turbo seals and is there any way of adjusting the pressure to make it lower if it is running high cheers
Old Jul 25, 2014 | 05:20 PM
nevsrevs's Avatar
nevsrevs
if your pump plunger in the prv is stuck that can cause issues, should see around 40/60psl on a warm tickover
Old Jul 25, 2014 | 05:22 PM
GVK.'s Avatar
GVK.
3.2 - 5.0 bar @ 4000 rpm is specified pressure. (source Autodata)
Old Jul 25, 2014 | 05:25 PM
Layland's Avatar
Layland
Cheers I will have a look at it again tommorow and check the valve not sticking cheers again
JK12
33
Apr 26, 2021 12:09 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
dombanks
Sep 21, 2015 08:38 PM
BRAM
Sep 8, 2015 07:11 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
