1.8 petrol 2003 mondeo
Old Jul 22, 2014 | 06:17 PM
tj358's Avatar
tj358
Default 1.8 petrol 2003 mondeo
03 ...1.8 petrol mondeo help some one i have a problem that when im driving and holding the throttle at any level for longer than 5 secons the car cuts out battery light and engine check light come on but soon as i push in clutch or take it out of gear it restarts its self and if ur happy with the throttle like on bendy roads it dont happen at al only when holding throttle at any one level any one no wats up wit tat .????
Old Jul 22, 2014 | 06:36 PM
RichieST's Avatar
RichieST
Start by getting the fault codes read, the light comes on as it has logged a code.
Old Jul 22, 2014 | 06:46 PM
tj358's Avatar
tj358
what do i do hold the reset button in for codes
Old Jul 22, 2014 | 06:48 PM
tj358's Avatar
tj358
man its a tricky problem according to a ford dealer mechanic and they are expensive yano
Old Jul 22, 2014 | 06:51 PM
RichieST's Avatar
RichieST
Any half decent garage can read the fault codes for you, needs plugging in to a obd reader.
Old Jul 22, 2014 | 07:11 PM
tj358's Avatar
tj358
its a tricky one but sure to god some one on here can help wit out having to plug it in yano and the irish aint big ford men jap imports now and we can solve it in our sleep yano
Old Jul 22, 2014 | 07:22 PM
tj358's Avatar
tj358
Angry urgent help required asap
...1.8 petrol mondeo help some one i have a problem that when im driving and holding the throttle at any level for longer than 5 secons the car cuts out battery light and engine check light come on but soon as i push in clutch or take it out of gear it restarts its self and if ur happy with the throttle like on bendy roads it dont happen at al only when holding throttle at any one level any one no wats up wit tat .????[/QUOTE]
Old Jul 22, 2014 | 07:50 PM
RichieST's Avatar
RichieST
Seriously - the car has logged a fault code, it is ready to tell you what is wrong with it. Other than that it's just a guessing game, could be anything, an internet diagnosis on a vague list of symptoms is of no use.
Old Jul 24, 2014 | 08:31 PM
tony66's Avatar
tony66
Default codes
you can get software and cable online very cheaply for this[vcds]=download and plug/play
or anybody with a snap on solus/modus etc will do it-as well as ford obviously
Old Jul 25, 2014 | 06:40 PM
tj358's Avatar
tj358
Default cheers
nice one tony got it sorted cleaned every sensor with brake cleaner including reset fuel pump and the connections ont the pump were brased lookin and few a the sensor connections were the same so done all that and its perfect.... thanks but
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
The Enigma
Sep 29, 2015 10:31 AM
