Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Focus mk1 .5 rattling at 3000rpm
Old Jul 19, 2014 | 04:34 PM
Thedonn's Avatar
Thedonn
Default Focus mk1 .5 rattling at 3000rpm
Hi people iv got a 1.6 mk1.5 focus, the problem iv got is that when it gets to 3000rpm i can hear this awful awfully annoying rattling, its smooth until i hit 3000rpm it sounds like its defiantly coming from the engine if anyone can help me sort this out would be great.
Thanks
Old Jul 19, 2014 | 05:11 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
, I would prefer to hear it for real, for instance take it to a mechanic you can trust,
or upload a video , and explain does the noise continue above 3000,,
are you using correct zetec engine oil , is the oil level ok ,
has it been serviced within last 12 months,
Old Jul 19, 2014 | 05:45 PM
Thedonn's Avatar
Thedonn
It seems to stop just after 3000 then start again, iv took it to a couple of garages they said they dont no what it is, iv dropped the oil an put new filter an 5w/30 semi oil, changed the plugs, its gettin a new clutch end of month gunna see if he can diagnose the problem, just wondered if any one on here has experienced this.
Old Jul 19, 2014 | 05:51 PM
mk2grp1's Avatar
mk2grp1
I suggest you try a better garage
as the "I don`t know what it is" answer is what my nan would have said
Old Jul 19, 2014 | 06:34 PM
Thedonn's Avatar
Thedonn
Did i not say in the last post that i was having my clutch done at the end of the month so I'm gunna see what e says, if u haven't got a suggestion as to what the problem is apart from take it to a garage witch is the obvious solution then don't comment
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
massivewangers
30
Oct 1, 2015 07:40 PM
Fudgey
Sep 17, 2015 01:06 PM
JamboRS
28
Sep 14, 2015 09:02 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
