Not starting/fuel pump
Old Jul 19, 2014 | 03:44 PM
saph in dorset's Avatar
saph in dorset
Wink Not starting/fuel pump
Hey guys
Went to start my car today having not started it for a few months.
I had to swap tue battery over as the old was was shot but having done so and cranked the engine over a few times to get the oil pressure up
I then went to start the car but it wouldnt start it just cranked over.
So did some investigation
Checked all fuses were ok
Pulled all the plugs out to check fuel was getting in which it was as they were soaked so with all the plugs out i cranked the engine to clear the excess fuel out
Having done that tried atarting again but still no luck.
So thought ok lets remove the fuel pump fuse and crank it over to try and get rid of any more fuel and the engine started and ran at idle and just above seemed abit lumpy but more revs and seemed ok.
So thought ok maybe there was still plenty of fuel in the cylinders allowing the engine to run
I then put the fuel pump fuse back in but again the pump primed but then wouldnt start.
So pulled the fuse out again and yet again it started, but obviously the pump didnt prime.
So with the fuse back in checked voltage at the pump and during the short prime was getting about 11v (battery is still lowish)
With fuse removed again staryed engine but only getting about 0.2v at pump so how can the engine be running whilst running i put the pump fuse back in and the engine died.
I am completely confused how the pump will prime but engine not start with fuse in
But with no pump fuse there is no pump prime but the engine will start after 15seca on cranking.
Now i havent checked the pump relay as got annoyed and left it (had food shoping to do)
Could this all be caused by a dodgy pump relay now sticking and a small voltage jumping across without the fuse or am i totaly wrong.
It has a clifford alarm but that seems to disarm correctly.
I have also removed the cut off switch in the boot and joined the wires together so this isnt the problem.
Any clues as im nearly out of ideas.
Old Jul 19, 2014 | 03:45 PM
saph in dorset
Sorry for the essay just realised how long it was.
I have thought about just rewiring the pump but ideally want a quick fix to
Mot it before i go any further.
Old Jul 20, 2014 | 12:33 PM
martysmartie's Avatar
martysmartie
Diaphragm in the regulator is faulty, it does not matter if the fuel pump ran all the time, as the excess would return.
Martin
Old Jul 20, 2014 | 01:36 PM
saph in dorset
I have a spare so will try it out
Old Jul 20, 2014 | 02:44 PM
saph in dorset
Swapped it out and still doing the same.
Wont start with fuse in. Take fuse out and starts.
Put fuse in whilst running and it cuts out.
Any more ideas?
Old Jul 24, 2014 | 06:31 AM
saph in dorset
Martin
Update
I have now installed a new adjustable fpr which i am now getting fuel from the return line, however the engine still will not run with the fuel pump on.
I have also changes the plugs but they are comming out very black after the enginehas been running without the fuel pump on.
Any thoughts?
Is there any reason the injectors could be permanently open or when the pump is on causing some kind of short even though the pump itself will work?
Im beggining to lose hope of it being ready for ford fair now so any help appreciated.
Old Jul 24, 2014 | 10:43 AM
jon@work's Avatar
jon@work
I would check the blue water temp sensor at the back of the head. The best way is to check the resistance between terminals 11 and 29 on the ECU hairbrush. You should have between 800 and 5000 ohms with the engine cold.
Some chips are written such that if the circuit is open (ie sensor has failed, or wiring not connected or broken) the ECU thinks the water temp is very low, so chucks massive amount of fuel in.
Old Jul 24, 2014 | 12:04 PM
martysmartie
What he said ^^, failing that look toward the MAP sensor.
Martin
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
