Brake problem cossie t25
Old Jul 16, 2014 | 09:37 AM
sigurdg's Avatar
sigurdg
Default Brake problem cossie t25
Hello.
I have some brake problems with my cossie t25, 1995mod. The pedal is rock hard and nothing on the brake-assistance/hydraulic units got 12V, nor the main valve or the hydraulic pressure pump.
The yellow single fuse under the dash on the left side, beside the clutchpedal is OK, so is the single green fuse on the left side in the trunk.
The car has been stored for a time, however in a dry place.
I have checked the batterypole and renewed some of the wires just to be sure it is not a bad connection.
Anyone know what the problem is?
Sigurd.
Old Jul 16, 2014 | 12:28 PM
jsa's Avatar
jsa
There are more fuses on relays lower down the left side of the trunk.
Old Jul 16, 2014 | 05:27 PM
sigurdg's Avatar
sigurdg
The 3 fuses sitting on relays in the trunk is not broken, but with ignition on they dont got 12V. The single fuse in the trunk is as mentioned fine, and got 12V.
Is there more fuses in the car that may be broken? All of the normal fuses under the dash is OK.
Old Jul 16, 2014 | 08:40 PM
jsa's Avatar
jsa
Have you checked the ones at the battery ?
Old Jul 16, 2014 | 09:35 PM
sigurdg's Avatar
sigurdg
Yes, those are fine.
Old Jul 22, 2014 | 09:18 AM
sigurdg's Avatar
sigurdg
No one knows?
Old Jul 22, 2014 | 11:16 AM
jsa's Avatar
jsa
Next step is circuit diagrams and follow it through
Old Jul 24, 2014 | 07:27 AM
sigurdg's Avatar
sigurdg
I cant find a wiring diagram for the t25, can someone send me one please?
original
Apr 28, 2026 05:20 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Red_bull
Aug 9, 2015 08:34 AM
