is this fuel pump voltage correct?
Old Jul 15, 2014 | 04:42 PM
dangerousbrian's Avatar
dangerousbrian
Default is this fuel pump voltage correct?
just fitted fuel pump and rewired it direct to battery as the pump was prev only getting 10v with lights/heaters etc on. i read that i should be getting altenator voltage at pump on idle but i am getting 12.8 alternator is at 13.7. lights on etc i am still getting 12.8 at the pump which may be a good thing but im concerned when driving it my not be good. i have used 27amp wire with 20amp fuse inline and a 12v 40 amp relay. i assume these bits correct to use? the relay is an old one i had lying about so is there a possibility the relay can be restrictive? or is the voltage ok? car is s1 rst if it matters. any help appreciated ta
Old Jul 15, 2014 | 04:58 PM
JOHNDQ's Avatar
JOHNDQ
defo seems a voltage drop there, yes relays can cause it if there's a resistance over the coil shouldn't be hard to find using a muti-meter all tho the pump will prob run fine with that voltage
Old Jul 15, 2014 | 08:19 PM
stevieturbo's Avatar
stevieturbo
C**t
Unless there is a substantial cable from alternator to battery, wire the power source directly to the alternator.
Ensure both power wire is suitably sized, and also the pump has a proper ground.
27A wire means nothing, what size/gauge is the wire ?
Old Jul 15, 2014 | 08:38 PM
dangerousbrian
not sure about gauge but it says on the label 12v 2.5mm. got the earth for the pump and the new relay direct to battery
Old Jul 15, 2014 | 08:45 PM
stevieturbo
C**t
Run the earth to a good clean point on the chassis local to the pump. It will be better than a long small diameter cable running all the way to the battery. You can double it up with the cable if you want.
2.5mm^2 isnt huge by any means but should be adequate.
I like to oversize pump wiring. 4mm would be better, even if it is overkill.
Old Jul 15, 2014 | 08:59 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
What stevie says.
Don't underestimate how critical a good earth is.
Old Jul 15, 2014 | 09:41 PM
GVK.'s Avatar
GVK.
Can do volt drop testing with car running, along the cables to see if you're losing power or ground.
You need to see as close to 0v as possible when going from the battery to the pump on the power cable, then same along the ground.
If your meter shows voltage when testing that will be where it's losing voltage (volt drop)
If for arguments sake you test the pump and its getting 12v when running, and you have 14v across the battery, you're losing 2v somewhere, if you volt drop test the ground and it shows 2 volts..hey presto..
More on volt drop testing here. http://www.fluke.com/fluke/uses/comu...sevoltdrop.htm
Old Jul 15, 2014 | 10:38 PM
Jimboxr4x4's Avatar
Jimboxr4x4
I have a digital Voltmeter in my dash to show pump voltage so i can monitor it under load. Easy to wire in and cost less than 2 quid on ebay.
Old Jul 16, 2014 | 12:41 AM
Rob Virgo's Avatar
Rob Virgo
Pics Jim please
Old Jul 17, 2014 | 09:10 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
that doesn't sound to bad to be fair, with engine revving a little better the amperage will increase from alternator and the voltage drop will be less. under load and some revs gives much better performance than idle/no load.
Old Jul 17, 2014 | 09:17 PM
Originally Posted by Rob Virgo
Pics Jim please
+2............
JK12
33
Apr 26, 2021 12:09 PM
jonfoc
16
Sep 11, 2018 05:35 PM
15
Oct 7, 2015 03:43 PM
RSmark84
Sep 13, 2015 01:29 PM
kevin36
Sep 8, 2015 12:23 PM
