MK1 FRS mtx75 speedo drive conversion ?
Old Jul 15, 2014 | 12:25 PM
rs milesy's Avatar
rs milesy
Default MK1 FRS mtx75 speedo drive conversion ?
Is it possible to convert the electronic speedo drive back to the mechanical type ? If so which box/speedo drive do you use ?
Thanks.
Old Jul 15, 2014 | 05:48 PM
cossirob's Avatar
cossirob
Id like to know this too
Old Jul 15, 2014 | 07:58 PM
studabear's Avatar
studabear
I've bought a mtx75 from a mondeo diesel that has a speedo drive, not sure if the bell housings are interchangeable but I think the diffs are.
Old Jul 20, 2014 | 07:33 PM
project rs's Avatar
project rs
the mechanical part needs taking of the mondy box and pressing onto elecy drive is a simple job for any gearbox place its with the bearing
Old Jul 26, 2014 | 08:47 PM
JesseT's Avatar
JesseT
There are also something called speedo cable drivers. A box where you feed the electric signal in and it rotates the speedo cable with matching speed. Not very difficult to make one either.
Old Jul 26, 2014 | 09:07 PM
studabear's Avatar
studabear
any links?
TPM961
Jan 15, 2018 10:50 AM
Kam B
Sep 24, 2015 10:40 AM
Eigdoog
48
Sep 19, 2015 11:03 AM
JamboRS
28
Sep 14, 2015 09:02 PM
IanC
Sep 5, 2015 09:38 PM
