mk6 fiesta bang from rear nearside
Old Jul 12, 2014 | 05:06 PM
Markt8's Avatar
Markt8
Default mk6 fiesta bang from rear nearside
As title, got a very loud bang from the rear suspension on passenger side of my 2005 fiesta, also the rear passenger side trys to follow bumps, any ideas as to what this is? Thanks
Old Jul 12, 2014 | 05:40 PM
Fullflush's Avatar
Fullflush
Bush maybe
Old Jul 12, 2014 | 05:57 PM
Shocker??Get the car jacked up and have a look.The rear beam bush might be worn.If it is when you shake the wheel side to side you should see and feel the play.
You could also get a wheel brace on the wheel nuts,go to tighten them and you should feel the play in the bush.
Check to see if the strut top/shocker top bush isn't worn either.
Old Jul 13, 2014 | 12:43 AM
Markt8's Avatar
Markt8
Will check tomorrow, seems pretty bad for a worn rear bush had a couple of mk5s with them but possible, when the back wheel hits a bump it flings itself towards the bump aswell
Old Jul 13, 2014 | 09:23 AM
bigjohn0's Avatar
bigjohn0
Rear beam bush will be shot so go for some Polly bush and forget about them once fitted
Old Jul 14, 2014 | 09:17 PM
Markt8's Avatar
Markt8
Just been checking the car tonight and the rear nearside shock is leaking badly, would this cause my problems?
mark
Old Jul 14, 2014 | 09:40 PM
studabear's Avatar
studabear
Yeah, I've changed a few on these, quite often the dust cover fails and then the shocker shits itself.
Old Jul 14, 2014 | 10:09 PM
grass racer's Avatar
grass racer
Yeah shocks are gone, had same problems when I bought my ZS changed the shocks now its perfect. You don't even need to get inside the car to do it.
1 bolt at the bottom take the wheel archer liner out and there's 2 bolts on the top inside the arch, easy job
Kyle Langford
27
Aug 5, 2019 07:54 PM
Botts
Aug 13, 2015 04:16 PM
Bosch
Aug 4, 2015 05:14 PM
