Help needed!!!
Alright chaps need a bit of help s2 rs turbo has no spark .. Soo traced back the wiring with the voltage meter and there is power going to the coil but no spark coming out as put a spark plug in the king lead and earthed it to the car and nothin! But I ordered a new coil from fleabay a Lucas one but the terminals where the live and positive go are shorter and smaller and the king lead connection is different can any one help? It says on the eBay ad it's for 86-90 escort rs turbos? But defo not right for my car...
It was really only cus i posted on here i got it sorted
Yeah but there's no spark coming from the coil in the first place and that's before it gets to the dizzy , the new coil the bit where u plug the king lead in its like further down the plastic but compared to the one I took of after I compared them if that makes sence? And the terminals were a lot shorter and not as thick so I crushed them with a pliers to make a better connection while I tried to get a spark from the king lead
so no earth no spark
you can get the sensor ebay again but for ease and price...
Yeah so that would stop the coil from getting a spark as we'll if this sensor was knackerd ? Ok I'll get myself a second hand dizzy but when you install a new dizzy do I need to mark where the bolt is on the old one in case I fuk the timing up?
the coil doesnt get a spark, the coil releases the energy to give the spark i think its all about the coil getting negative earth from the signal generated by the hall sensor via the silver ecu which then fires the coil
fit replacement as original is positioned, marker pen or something
cannot go too wrong as the drive is off centre, check new dizzy has a seal on it
or you will lose oil from the engine, try the part off your mate for peace of mind
an xr3i dizzy no good as its different
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
rog
Sep 4, 2015 12:10 PM
borboyous
Aug 22, 2015 11:17 AM
