Best Way To Remove BodyKit
Old Jul 10, 2014 | 02:25 PM
HaggisTurbo's Avatar
HaggisTurbo
Default Best Way To Remove BodyKit
So, having to break my Orion Ghia as it's rotten and I am having a heck of a time with taking the Orion RS Bodykit off.
I have managed to get the bumpers off ok but I am really struggling with the sideskirts, There is 4 screw holes in them which attach it to the bodywork. I have removed these, but the person who fitted them has also used silicone and some sort of bonding sealant.
i have managed to get the first 30cm or so detached from the car but struggling to get anymore off and I don't want to damage the kit.
Is there an easy way / or any tips on how to get this thing off? We can break through the top silicone seal and get a bit of wire down there but its not strong enough to cut through the bonding agent.
Thanks Guys
Old Jul 10, 2014 | 02:39 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
long Stanley blades the snap off type and plenty of lube or washing up liquid
a really sharp fillet knife might do it , but its gotta be razor sharp
, just stroke along with a bit of pressure
the 4 screws you removed went through the kit, theres probably an expanding raw-plug type fixing on the backs of the rubber sills , so cut upto these ,and around them,
or through them , they are much tougher than silicone
you could use an oscillating tool but the helper has got to be sensible
and not just a bod with no skills or patience, they can`t even make decent cuppa Tea !
Old Jul 10, 2014 | 03:11 PM
Lee Grout's Avatar
Lee Grout
Big knife out your kitchen, don't let the mrs find out you took it!
Old Jul 10, 2014 | 03:55 PM
HaggisTurbo
Haha Lee I can imagine the look i would get when the knife id blunt, bent and has silicone on it lol, mk2grp1. I will give that a go, I noticed the rawl plugs and I think that is what is stopping the bodykit peeling back any further as its resisiting at that part to the point I kept checking if there was actually still a screw in it!.
What does the lube / washing liquid do? does it make it easier to move the knife or does it break doen the silicone? Reason I ask is that there is literally enough room for a thin knife blade so not sure how I would get the liquid down there
Old Jul 10, 2014 | 04:20 PM
mk2grp1's Avatar
mk2grp1
I creates a slip effect when the blade is dry, and its gonna be dry,
dilute abit, and dispence out of a trigger type bottle,
wd40 would be expensive but would do it
snap off stanleys are about 6inch long, a new blade will soon go blunt,
I wasn`t saying the raw plug thingy was holding it
just making you aware of what you cannot see , when you hit something hard
craft knife type thing, that's a Stanley only longer,
Old Jul 10, 2014 | 04:22 PM
mk2grp1's Avatar
mk2grp1
won`t break down silicone, just gives glide instead of grip
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
