Gearbox noise propper getting me cheesed off
Old Jul 10, 2014 | 10:21 AM
neo's Avatar
neo
Default Gearbox noise propper getting me cheesed off
Default Gearbox noise proper getting me cheesed off
Hi guys had my escort gearbox put in the car after the restoration and it was supposed to be a good box its turned out another nightmare just like everything else i bought off the same guy on here...
But i had the gearbox sent to TVT in Newcastle whom stripped and rebuilt the box due to a constant type bearing noise its been done and new bearings fitted also they fitted the following bits..
1. New lay shaft
2, drop gear
Ive refitted the gearbox all new oils etc etc after a £475 rebuild and its exactly the same noise on it...
Ive sent both prop shafts into be checked and they are perfect no problems at all there the noise is right under the gear lever area and is there constantly even free wheeling at speed...
all mounts are new etc etc...
below is a video of the noise from inside the car what's your thoughts guys
Im proper cheesed off with the whole thing now to be fair..
http://vid387.photobucket.com/albums...ps7f62a1d0.mp4
Old Jul 10, 2014 | 08:26 PM
Cossy Mike's Avatar
Cossy Mike
Vid not work......
I took mine to Terry at GRS in Newburn, he's the daddy for MT75 boxes.......maybe worth a try?
Even just a chat. He only took £100 off me to strip it all, degrease it, check it, fit a bearing and all seals and given the all clear
Old Jul 12, 2014 | 10:38 AM
RIB1122's Avatar
RIB1122
transfer chains can make a noise like a bearing
Old Jul 12, 2014 | 10:39 AM
RIB1122's Avatar
RIB1122
Originally Posted by saphcosmike
Vid not work......
£100????
there are 5 seals on a cossy box must cost £40?
fit a bearing £30?
and the labour must be 4 hours
Old Jul 12, 2014 | 08:02 PM
neo's Avatar
neo
Works now mate
Ive had car on a 2 poster ramp today with gearbox man underneath its the transfer box making the noise
So yet another scrap part of the guy i bought my bits off....on here
Old Jul 12, 2014 | 08:23 PM
markk's Avatar
markk
Surely that can't be hard to find.
Old Jul 14, 2014 | 07:01 PM
neo's Avatar
neo
i know you would think that would'nt you
Its getting a transfer box chain and bearings in when the guys gets back 2/3 weeks time
bloody holiday season...
Old Aug 27, 2014 | 08:03 PM
Cossy Mike's Avatar
Cossy Mike
Originally Posted by RIB1122
£100????
fit a bearing £30?
Yeah mate £100 cash
Seals and input shaft bearing, picked if up 4 days later
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Iain Mac
Sep 30, 2015 09:39 PM
