Injector and Throttle Body advice for Zetec Turbo
Old Jun 22, 2014 | 08:38 PM
HaggisTurbo's Avatar
HaggisTurbo
Default Injector and Throttle Body advice for Zetec Turbo
Hi all. In the US for a few weeks.
Whilst here was going to get myself some Siemens deka 630cc /650 cc injectors for my Zetec Turbo build as they are a fair bit cheaper over here. Which ones is it I need specifically?
I am also going to get an aem wideband kit as its a fair bit cheaper or is there a better brand?
Finally is there a bigger throttle body I can get that will flow better than the 2.0 blacktop one I have just now that I can get here?
Is there any other bits I could benefit from bringing back?
Thanks all
Old Jun 22, 2014 | 09:39 PM
studabear's Avatar
studabear
What inlet you planning on using?
I've got the aem afr set up on mine and also run siemens deka 630cc injectors.
Old Jun 22, 2014 | 10:26 PM
HaggisTurbo
Hi mate. It's a start blacktop inlet I have at the moment mate. What deka injectors do I need as I see there are different widths and models etc.
Old Jun 23, 2014 | 09:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
These...
http://www.performancebyie.com/sieme...high-impedence
Old Jun 23, 2014 | 11:57 PM
HaggisTurbo
Thanks Karlos there is an option of stubby or slim? And also EVO fitment is that correct?
Old Jun 25, 2014 | 05:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Not on that site there isn't?! No, Mini timer or EV1 fitment.
Old Jun 26, 2014 | 02:37 AM
HaggisTurbo
Thanks Karlos, I found a place that did them cheaper but they had the option of EVO and other options and wanted to make sure I was going to buy the right ones
Old Jun 28, 2014 | 02:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ah I see, you of course could use EVO fitment and stubby's but you'd have to change your plugs and modify the fuel rail too! lol
Old Jun 29, 2014 | 04:21 PM
HaggisTurbo
Put the order in got these injectors:
http://www.ebay.com/itm/281352080306
and this AEM Wideband:
http://www.ebay.com/itm/360538007974
Hope I have the right ones and that they turn up in time lol
robnock
21
May 13, 2019 05:29 PM
Dicko&Vacant
Aug 21, 2015 05:59 PM
Chopshop85
Aug 17, 2015 06:38 PM
nick8saff
Aug 16, 2015 05:35 PM
M K
Aug 12, 2015 06:57 PM
