help with diagnosis please
Old Jun 9, 2014 | 09:51 AM
dangerousbrian's Avatar
dangerousbrian
Default help with diagnosis please
just noticed when sitting in the car with it running that my fuel pump changes tone when working electric windows and the tone pulses with the hazards on. is this the pump knackered or have i got dodgy wiring somewhere. i assumed it was the pump but not so sure now. its escort s1. cheers
Old Jun 9, 2014 | 11:17 AM
Stu @ M Developments's Avatar
PassionFords Creator
VERY bad wiring mate.
Old Jun 9, 2014 | 12:36 PM
dangerousbrian
thanks for the reply. is this symptons of dodgy fuelp pump wiring as ive read this is problematic on these donkeys
Old Jun 9, 2014 | 06:19 PM
LHD220Turbo's Avatar
LHD220Turbo
you really must re-wire the fuel pump with a direct feed from battery; this ensure you get the max volts at the pump.
just think what volts you'll be getting at full chat with all the electrics on! you risk melting your engine if you dont
Old Jun 10, 2014 | 03:21 PM
Check for over 12volts at your pump. You might get a shock cause how low the voltage is.
Old Jun 10, 2014 | 04:03 PM
dangerousbrian
checked the voltage at the pump and its getting 12.1v. is this too little?
Old Jun 10, 2014 | 04:23 PM
Is that with the engine running. It should be a bit more than that. What power is your alternator putting out.
Old Jun 10, 2014 | 04:33 PM
dangerousbrian
yeah thats with it running. im getting 13.7 from the alternator.
Old Jun 10, 2014 | 06:27 PM
LHD220Turbo
no point checking it at idle; its when you are boosting is where its most important
Old Jun 10, 2014 | 07:58 PM
dangerousbrian
probably a daft question but why does thpump need more than 12v if its a 12v system?
Old Jun 10, 2014 | 08:10 PM
St3V3_C's Avatar
St3V3_C
You'll be fine as long as you don't indicate when you're flat out overtaking someone lol.
Get it rewired!
Old Jun 10, 2014 | 08:32 PM
dangerousbrian
[/URL]
Get it rewired!
very good
i found this but its for a series 2, is this the same principal for a s1? better check as i know the original relays are different. car has started misfiring badly when pulling away now so need to get this sorted as its supposed to be getting setup thursday. cheershttps://passionford.com/forum/ford-e...mp-s2-rst.html
Old Jun 10, 2014 | 09:42 PM
2Litre's Avatar
2Litre
It is more than likely you have a voltage drop due to poor wiring and or output of your alternator.
Yet at the same time fuel pumps that are not used as they were designed to be used (Daliy) die in no time.
I hardly use my car and as a result have had two new pumps give up, and it is certainly nothing to do with wiring (Fuel/dirt/religious intervention)
If you have upgraded your loom and eliminated resistance due to voltage drop the answer is the use your car more!
Preventative maintence is the cure.
My Best. Tim.
Old Jun 10, 2014 | 09:53 PM
stevieturbo's Avatar
stevieturbo
C**t
It's called a 12v system, but in reality with the engine running it should be running at around 13.5v-14.5v
The pump will quite happily run at 12v, but it will flow less. However the fact there is a volt drop from source...ie alternator to pump of almost 2v. That IS the problem.
That means there is bad wiring somewhere.
Old Jun 10, 2014 | 09:57 PM
RichieST's Avatar
RichieST
Put your lights, wipers and heater blower on then see what voltage you have at the pump.
Old Jun 10, 2014 | 10:12 PM
2Litre's Avatar
2Litre
As stated above , a seized pump draws more current and as a result places more demand on the battery and wiring!
Its a process of elimination.
Good luck.
Tim.
Old Jun 11, 2014 | 08:15 AM
dangerousbrian
thanks for the help. if i rewire it as in the link above does that keep the original fuel pump relay? ie put new relay between original relay and pump? want to make sure it wont put extra load on the original relay as they are getting hard to come by now and dont want it to fry! cheers
Old Jun 11, 2014 | 08:18 AM
BigErn's Avatar
BigErn
Bloody hell Lee, thats not good. Get it rewired before you go to Karl.
Old Jun 11, 2014 | 08:43 AM
dangerousbrian
tell me about it ern, no surprise with this car though. trying to get as much info on here as i can before i start although with a fuse i shouldnt set fire to anything....hopefully ha
muffster
13
Sep 3, 2015 09:40 PM
Rollinz
Apr 14, 2012 05:47 AM
benscab
Ford Focus RS
Sep 22, 2010 06:06 PM
Stu.H
33
Jun 9, 2009 08:02 PM
3dr Grot
Dec 1, 2007 05:04 PM
