Ford Range This section is for other models in the Ford range.
2.0 Blacktop Head on Silvertop Zetec
Old Jun 2, 2014 | 11:16 AM
DaveJB's Avatar
DaveJB
Default 2.0 Blacktop Head on Silvertop Zetec
Hi,
I've been reading threads from the past few years about this.
I know it's possible, but with work.
Some posts say you can mix and match a silvertop and blacktop tensioner kit, others say you need to weld up a core-plug on the blacktop head and drill/tap it and use the silvertop tensioners.
Is there a definitive answer please, ideally with some photos?
The reason I want to go down this route is that my silvertop stem seals are goosed and a friend has given me a known-good working blacktop head c/w aftermarket cams for nothing so it's the best route to take for me.
The engine is in a kit-car so I have no other issues with ancilliary equipment and mountings etc.
Thanks for your help
dombanks
Sep 21, 2015 08:38 PM
Chopshop85
Sep 12, 2015 06:42 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
BRAM
Sep 8, 2015 07:11 AM
