Ford Range This section is for other models in the Ford range.
Ford Cougar - please help!
Old May 30, 2014 | 03:09 PM
Kirsty29's Avatar
Kirsty29
Default Ford Cougar - please help!
My cougar has failed it's mot. It needs a replacement rear subframe. I can't find 1 anywhere. I've been told that the mk 2 mondeo 1 might fit. Is anybody able to confirm this for me please?
Old May 30, 2014 | 04:12 PM
chris cdti's Avatar
chris cdti
Yes they are basically the same car. Make sure you swap the roll bar over as the cougar one is stiffer than a mondeo one. Unless you get a st200 rear subframe.
Old May 31, 2014 | 06:18 PM
Kirsty29's Avatar
Kirsty29
Thank you for your reply. I have now found 1 from a cougar. My other half is going to fit it. Do you know how much is involved with the change over, i.e - Does the subframe hold the springs in place? Sorry if I sound stupid!! I don't have a clue myself, just worried about letting him loose on my baby!!!
Old May 31, 2014 | 06:27 PM
chris cdti's Avatar
chris cdti
if you have one with all the arms still fitted it will make the job 100% easier. As the arms have oliptic washers for adjustment and getting them in the correct place with no tracking tools is no hope. The springs are on the rear dampers so you will be ok on that.
The frame and arms are held in by bolts so straight forward to do. Only thing you will have to do is make sure the subframe is in the correct place before tightening the bolts to the body. Two long sockets could be used to get it close as poss with having to buy the special dowles to do it.
Old Jun 1, 2014 | 08:36 AM
Kirsty29's Avatar
Kirsty29
Thank you, I will pass all that on to him, I'm sure it'll make more sense to him then it does me (or at least I hope it does!!!) Part arriving end of the week, wish us luck!!
Old Jun 1, 2014 | 08:55 AM
chris cdti's Avatar
chris cdti
Good luck and get some wd40 etc as them bolts would of been in there for around 13/14 years.
Old Jun 1, 2014 | 08:58 AM
Kirsty29's Avatar
Kirsty29
Otherhalf as already started spraying them in the hope that by the time he comes to do it, it may have started working a bit!!
Billy_RS
16
Oct 11, 2025 09:41 PM
Ford Focus ST Parts for Sale
Aug 28, 2015 01:32 PM
borboyous
Aug 22, 2015 11:17 AM
RockinRein
Aug 19, 2015 07:08 PM
