Advise needed clutch slips when boosting
Hi, I am after some advise, my 1990 S2 drives fine until it boosts then the clutch slips in all gears but only when it boosts, you can drive it along the road at 30mph in 5th and it won't slip until it boosts, now I've spoken to the previous owner who had the engine rebuilt and put a new clutch in it and had the flywheel skimmed. But when he'd finished all that he then put a superchips ecu in it but he does not know to what point it was chipped to . Now my question is or questions rather are
1, should the clutch all be it a standard one be able to handle the power when it boosts if it is indeed new and the flywheel has been skimmed and the like.
2, if the answer to the above is no, then what clutch would you recommend, as far as I know all that has been done to the car is the chip, it's got standard airbox and there's no other bits been added.
3, if the answer to question 1 is yes it should then why is it happening and what can I check to try and sort it before the gearbox and the like have to come out.
How we'll do you trust the previous owner for a start? Is it definitely a new clutch?
Is it contaminated? Causing it to slip prematurely? Is the clutch fully engaging/disengaging? All things that need ruled out first. Then I'd go and inspect the clutch?
You really need more information to make a decision.
They are self adjusting clutches so i believe. How do I check it's engaging/disengaging properly.
I suppose if I can get hold of a standard ECU and fuel ecu I could put them on and check if it still does the same.
What power/boost are you running? A stock clutch will slip about 170bhp/ftlb IME, roughly 14psi on a stock engine/turbo.
Just to point out the chip does not control the power or boost directly, it simply removes the boost cut and in some chips has a revised ignition map.
i fitted a Q&H clutch as a temp measure to an escort turbo i had a few years back my car was only running 14psi and it didnt take long before it started slipping, after i pulled it out and fitted an AP organic i never had any bother with it..
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
