RS Turbo EFI - Boost and Idling Issues
Old May 27, 2014 | 12:42 PM
HaggisTurbo's Avatar
HaggisTurbo
Default RS Turbo EFI - Boost and Idling Issues
Hi All,
Having a bit of bother with one of my cars.
Its a Fiesta RS Turbo EFI engine in an escort and running OFAB on a T3
It is having some problems which are beginning to drive me mad, Would appreciate any help i can get with them
- Idles Poorly, sounds really lumpy, Cleaned the ISCV and it got a bit bitter but still lumpy
- When on boost it picks up fine but as soon as you got flat out in any gear the car starts kangarooing, (lunges back and forward but boost pressure doesnt appear to change on the gauge) but is really violent till you let your foot off the gas
Car isn't chipped , Any ideas?
Old May 27, 2014 | 03:12 PM
s1cab's Avatar
s1cab
Had it been set up properly ?
Old May 27, 2014 | 06:24 PM
HaggisTurbo
That I don't know mate as it never really ran properly just could never figure it out any ideas?
Old May 27, 2014 | 07:15 PM
s1cab's Avatar
s1cab
Just get it set up, it will most proberly sort the issues out aswell
Old May 27, 2014 | 09:27 PM
Red_bull's Avatar
Red_bull
Boost limiter? or don't these ECU's have em?
Old May 28, 2014 | 10:19 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Originally Posted by HaggisTurbo
Hi All,
You've fitted a bigger turbo and no chip to fuel for it so my guess is you are dangerously lean!
You need to fit at the very least Beige injectors and a chip to suit those injectors and a T3.
Old May 28, 2014 | 11:15 AM
HaggisTurbo
I tried turning the boost down to 3 or 4 psi and it is still doing it, I wouldnt have thought it would have needed chipped if it was running low boost and standard injectors?
Old May 28, 2014 | 12:12 PM
mentalasanything's Avatar
mentalasanything
Not sure about the kangarooing, most likely to be fueling.
On the lumpy idle, check the crank case breather filter isn't clogged up and that the vacuum pipework from the inlet manifold to it is clear.
Lee
Old May 28, 2014 | 12:23 PM
HaggisTurbo
Mentalasanything, funny you should say that as it pops the dip stick out all the time, could this be a blocked breather then?
Old May 28, 2014 | 02:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes it would, the T3 is a lot bigger than the original T2 and so flows much more air at the same boost pressure.
If once you've checked the breather system it is still blowing the dipstick out then you may have high crank case pressure (worn rings perhaps).
Old May 28, 2014 | 02:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
EFI isn't like MFI mate, there is not really anything to setup as such, idle CO and base fuel pressure are the only adjustments available (these could of course be miles out), beyond that it's a remap.
Old May 28, 2014 | 03:42 PM
s1cab's Avatar
s1cab
I noticed it had a t3 fitted and wondered if it had been setup since as in fueling checked etc. If your not 100% its always worth getting it checked/setup properly imo
Old May 28, 2014 | 05:27 PM
boeb's Avatar
boeb
Got very similar problem haggis....except a get 2 laps at knockhill then it starts....made me look like a right nutter at ford live lol...had co and base done already
Old Jan 15, 2019 | 09:46 AM
90_spec's Avatar
90_spec
I know this is an old post, but i have the same issues and wondering if a 165 Chip or something similar really does just sort most of it out with the CO set up etc, as it seems really off to me.
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 17, 2015 12:21 PM
marky_g
Aug 15, 2015 10:43 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
