Engine warning light on
Old May 25, 2014 | 08:38 AM
badman1's Avatar
badman1
Default Engine warning light on
Hi,
I replaced the Intercooler to Egr valve pipe yesterday as the old pipe had split. On starting the engine after finishing, I noticed the engine warning light did not go out. I have checked the electrical plug on Egr valve and the one on plastic pipe at bottom ( the pipe which is fastened to sub frame and has a rubber pipe to the Intercooler on other end ) of radiator, I found I had forgot to reconnect the vacuum pipe on the Egr. After I reconnected it the light is still on, engine runs perfectly, plenty of power, no unusual noises. Does the light have to be reset via code reader/computer?
Thanks for any help or suggestions.
Badman.
ps. The car is a mk3 2.0L TDCI 96kw mondeo titanium estate with the electrical Egr valve.
Old May 26, 2014 | 09:18 PM
gazza2502's Avatar
gazza2502
Disconect the battery for 30 min
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
