fuel pump relay.
Old May 19, 2014 | 08:48 AM
gi2490's Avatar
gi2490
Default fuel pump relay.
hi all,
new to this site and cosworths so please bare with me.
i have a mk1 escort and just been given a 2wd cosworth engine.
i have the engine bay harness and ecu. the harness has 2 relays both yellow.
1 black connector and i yellow. i think the black is for the fuel pump.
there is also a purple connector with no relay, is this used.
ok. my problem is i have a self contained fuel system in the car, seperate relays and fused.
can i do away with the relay on the loom or do i need to use it because of the ecu. if so HOW.
any info would be great.
thanks
Old May 19, 2014 | 09:07 AM
oldford's Avatar
oldford
You can find wiring diagrams here: http://bigturbo.co.uk/main6.htm
I think you can replace the fuel pump relay for your own. Don't forget the amal valve and the Idle speed valve!
I would keep the main relay as it feeds the ecu, ignition coil and the injectors.
Old May 19, 2014 | 11:11 AM
gi2490's Avatar
gi2490
any one got any more advice.
what is the purple connector for
Old May 19, 2014 | 12:28 PM
Sierrasideways's Avatar
Sierrasideways
Same thing with my car, 2WD Saff Cossie. Purple connector is connected to nothing and it all still works fine. I'm not an expert but possibly it's for aircon or some other addition that isn't in the car.....who knows? I'd like to know too though!
Old May 19, 2014 | 05:29 PM
opposite lock's Avatar
opposite lock
I would leave the relays alone and use the saph fuel relay 12v+ (pin 87) to trigger your new fuel relay/s.
Once the ECU is activated its pin 28 that activates earth switch to the fuel relay (pin 85 ) which in turn provides the 12v+ at the pump ,iscv and boost solenoid.
Old May 19, 2014 | 07:13 PM
gi2490's Avatar
gi2490
thanks for the replys.
so i take it from pin 87.
to my relays pin 85.
is that right
Old May 19, 2014 | 07:33 PM
3drzetec's Avatar
3drzetec
isn't the purple relay for the fuel cut off in the event of an accident
Old May 20, 2014 | 12:56 PM
opposite lock
is that right
It depends how you have wired your new relays in. If pin 85 on your new relay is the 12v+ 'trigger' on the coil side then yes the above will be correct.
Old Jul 5, 2014 | 12:57 PM
gi2490's Avatar
gi2490
okay i have wired my pump relays like this.
http://img.photobucket.com/albums/v2...4f/o44pump.png
using the old blk/r thick wire for the fuel pump as the trigger.
when i power up the signal from that wire comes back earth.
any suggestions please.
Old Jul 5, 2014 | 01:25 PM
martysmartie's Avatar
martysmartie
No, Saphs did have cut off switches for this reason though!
That is correct, do you actually have the ECU etc powered up yet? If not it needs to be...
Martin
Old Jul 5, 2014 | 01:33 PM
gi2490's Avatar
gi2490
yes i have main 12v feed from battery.
12v switched.
earthed through the harness.
head scratching time
Old Jul 5, 2014 | 01:40 PM
gi2490's Avatar
gi2490
this is how i have wired the engine loom
http://media.turbosport.co.uk/2006/7...9129027100.gif
with this for the fuel pumps..
all relays ok.. all fuses ok.
Old Jul 5, 2014 | 01:52 PM
martysmartie
But you say your not getting a supply from the trigger, therefore, ground it.
If you have power, then it is not being switched via the ECU.
Martin
Old Jul 5, 2014 | 01:59 PM
gi2490's Avatar
gi2490
hi martin
the ecu is grounded
Old Jul 5, 2014 | 02:06 PM
martysmartie
I am referring to the relay...
The relay is grounded via the ECU, but if is this is not happening it would explain why you have no power from it.
Therefore, if you ground the relay this should close it.
Martin
Old Jul 5, 2014 | 02:21 PM
gi2490's Avatar
gi2490
hi martin
i will try that tommorow.
will keep you posted.
thanks
Old Jul 5, 2014 | 02:39 PM
opposite lock
Make sure you have a good earth for the pump itself .
If you only want your new relay/fuel system setup connect pin 28 wire to the trigger side on new relay. That can be 86 or 85 and earth the other side .
If your battery is in the boot earth the pump direct .
Old Jul 8, 2014 | 12:23 PM
gi2490's Avatar
gi2490
hi martin.
i made new relay harnesses as they were a bit rusty. grounded the relay as suggested.
still showing earth from fuel pump wirel.
any more ideas.
electrics not my best point.
Old Jul 9, 2014 | 07:32 AM
martysmartie
PM replied to.
Martin
Old Jul 9, 2014 | 01:36 PM
gi2490's Avatar
gi2490
all relays fine.
power going to ecu all okay.
the one thing i dont have on is the amal valve. i am using manual boost control.
would this affect the ecu.
Old Jul 10, 2014 | 07:02 AM
opposite lock
did yoy manage to sort it out?
Old Jul 10, 2014 | 07:05 AM
gi2490's Avatar
gi2490
no still struggling.
all relays fine.
Old Jul 10, 2014 | 07:12 AM
opposite lock
so all your relays and fuses are fine and have power at the ECU.
Check the wiring associated at the hairbrush and give them a clean up.
ECU turns the pump on as said^ via pin 28.
Is the pump earthed well and is it new/old??
Not sure about the amal valve but im sure ive unplugged mine before and started the car so no effect there imo.
Old Jul 10, 2014 | 07:17 AM
gi2490's Avatar
gi2490
all brand new wires for the pumps.
will clean hairbrush connector.
after that god knows.
Old Jul 10, 2014 | 10:59 AM
gi2490's Avatar
gi2490
one of the pins is bent and not connecting in the chip, within the ecu.
i take it this may be the problem.
and nowhere on kos to fix ecu's.
Old Jul 10, 2014 | 12:14 PM
martysmartie
So you have power @ the OE relay? If it does not close, you have a faulty relay? (assuming you have it wired correctly)
The ECU is irrelevant as this is not controlling the relay (as you grounded it).
Martin
Old Jul 14, 2014 | 10:30 AM
opposite lock
edited.
Old Jul 17, 2014 | 01:23 PM
gi2490's Avatar
gi2490
IT LIVES again.
after all your input and advise. a lot of checking rechecking and checking again, i found the problem.
2 faulty brand new relays.
so 2 more sent from athens, another 55 euros, so 110 euros in totall.
i also installed a new chip. pins looked nasty.
hey presto, the beast lives.
thanks for all our advice guys.
will post a video asap.
Old Jul 18, 2014 | 05:41 PM
martysmartie
As I said above then
Glad it's running.
Martin
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
