-31& -34 actuators??
Old May 10, 2014 | 06:19 PM
little bram's Avatar
little bram
Default -31& -34 actuators??
Hi now I know the -34 has a stronger spring to cope with higher boost pressure but at want point would you change from 31 to 34. I've got a -34 on mine escort now and was wondering if it would be better to run -31? My car needs setting up again anyway and I also have a -31. Last time it was mapped it was at 25psi but now done so changes would have thought it will be going up. Will it be ok or should I change it.
Thanks
Lee Bram
Old May 10, 2014 | 06:33 PM
firthy's Avatar
firthy
Can't see your car needing a -34 tbh
That's what I run on my saff
Old May 10, 2014 | 06:56 PM
little bram
Why tho isn't it to hold boost pressure? Say if it gets mapped to 2bar would that be reason to leave it?
Old May 11, 2014 | 11:26 AM
Karlos G's Avatar
Karlos G
Balls Deep!
You would normally set your actuator pre-load to half your target boost, so if you want 2 bar you would need a -34 for example a -31 may creep open.
Old May 11, 2014 | 02:06 PM
little bram
Ok so would be best to leave the -34 on then. but say I didn't set the boost that high would it then be better to change down to -31 or would there be no different?
Old May 11, 2014 | 02:28 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
I had to change to a -34 on my RS as it was creeping open,i ran 1.6 bar
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
