transit connect problem selecting reverse ?
For the last 5/6 weeks my connect has been hard to get into reverse every other gear selects fine. At a guess i would say sometimes it can take ten attempts to select reverse. It makes no difference if the engine is running or switched off.
I have fitted a new Luk clutch kit including slave cylinder and a new gear selector cable, but still the problem is there.
So i'm guessing there must be an issue inside the gearbox ? If it's the box am i better off trying to source a second hand box or try to get my one repaired ?
It's a 1.8 transit connect 230L TDCi 90bhp
Any ideas ?
Any ideas ?
The annoying ginger guy
It has a series of sliders which control the individual gear and I've know something to break and get in the way of the reverse push down/lift up motion I.e reverse switch/spring/slider,
It's worth a check incase a Ł5 reverse switch is stopping you from selecting reverse or a worn selector
Must be inside the box then. If your gonna take the box out I reckonmend dropping the gearbox mounts off but have a jack under the box then use a scissor jack and put at the back of the engine and subframe and wind the engine forward so that the box clears the corner of the sub frame.
I am experiencing the exact same problem after picking up my 2007 transit connect a few days ago. My van will not go into reverse.
I suspected the clutch as I also had a small clunk when changing from first to second only , but the guy reckons he will throw in another gearbox and it will be fine.
Did this solve your issues ? I hope it solves mine!
Mitch
The Enigma
Sep 12, 2015 10:12 PM
